Where does this Spring belong
Old Oct 28, 2024 | 11:51 AM
Safari's Avatar
Default Where does this Spring belong
Found this spring laying in the driver's side foot well. It came from somewhere under the dash.
I don't think it's part of the brake or throttle pedal.
Where does it belong?
2007 Jaguar XK Convertible.
Thank you!
Old Oct 28, 2024 | 01:04 PM
Cee Jay's Avatar
Just taking a guess here by comparing to other vehicles I've had, on the brake pedal mechanism?
Under the throttle pedal to keep it upright from the linkage?
Old Oct 28, 2024 | 01:19 PM
Safari's Avatar
Its not strong enough to act as a bake pedal return spring. Its a lightweight spring. It might attach to the brake or throttle pedal but that's only a guess.
I'd just like to have an idea of where it belongs before I try to shimmy my plus size frame under the dash. ;-)
I found a picture that shows the brake pedal assembly. You can see the return spring. It's not the same as the one I found laying on the floor.
Old Oct 28, 2024 | 01:57 PM
Cee Jay's Avatar
I thought it may be the brake light SWITCH spring, not a return spring. I've never looked at a Jag brake switch. T'was a guess.
Old Oct 28, 2024 | 02:02 PM
Safari's Avatar
My first thought was the same but the brake switch is a plunger style with a built-in spring.
Old Oct 28, 2024 | 05:46 PM
steve_k_xk's Avatar
Hard to gauge the size of the spring however I know there is a spring on the plastic flap just above the steering wheel
Old Oct 28, 2024 | 07:09 PM
Safari's Avatar
I added another photo to my original post so you can get a sense of the scale of the spring.
I don't see a flap above my steering wheel. I will take a closer look tomorrow.
cdma
Mar 10, 2024 04:56 PM
rod9669
Mar 13, 2023 06:18 PM
No Quarter
Apr 21, 2022 03:40 AM
Vonnslingo
Jan 16, 2022 07:52 PM
adenshillito
Apr 16, 2021 10:01 AM
