Whining Noise
Old Dec 25, 2018 | 02:54 AM
DannyJ's Avatar
It's not air leak ... checked this one already
I suspect a bearing maybe but can't find any
Old Dec 25, 2018 | 02:56 AM
peterv8's Avatar
Sounds very much like air to me, not bearing but I'm no expert!:-)
Old Dec 25, 2018 | 03:02 AM
DannyJ's Avatar
All air intake pipes up to throttle are well connected, vacuum reading is good, idle stable, air intake to cabin hose is disconnected, A/C off, so air system is in good shape
Old Dec 25, 2018 | 07:21 AM
pwpacp's Avatar
If this is from inside the cabin, perhaps take a look at the temperature sensor fan on the instrument panel or look into the seat back fans. I agree that generally it does not sound like a bearing though. It is hard for me to hear in that range but it seems like a harmonic that something is emitting.
Old Dec 25, 2018 | 10:50 AM
DannyJ's Avatar
I checked the temp sensor. What is the seat back fans ?
Old Dec 25, 2018 | 11:59 AM
Brewtech's Avatar
Gotta get yourself the stethoscope. Shooting in the dark is fun too.
Old Dec 25, 2018 | 01:27 PM
pwpacp's Avatar
On the back side of the seat is a screen that has a fan behind it. Item #21.
I really doubt it could be the source as the sound is more of a whistle than what I would expect to hear as whispy from that component.
Old Dec 25, 2018 | 02:57 PM
  #28
DannyJ's Avatar
That fan is not an option in 2008 model, only from VIN 32753
Also, as mentioned, the noise follows precisely the engine revs so seems that it can't be from the cabin after all
Old Jan 3, 2019 | 01:46 PM
TexasTraveler's Avatar
Sounds very similar to alternator whine in stereo system. I know you said the stereo is off, but is it possible that the amp may still be getting power and feeding noise thru one of the channels? Just a guess...
Old Jan 4, 2019 | 10:25 AM
  #30
DannyJ's Avatar
Alternator is a real suspect for sure
that’s why I disconnected the speakers to make sure it’s not electrical induced noise
is there any additional speaker under dashboard such as burglar alarm or so ?
however it seems to me that the alternator bearing is whining at some level so maybe mechanical induced noise with all that aluminum monococ structure ?
i plan to make some access to the front pulleys and check them all
what is the easiest way doing so ?
Old Jan 4, 2019 | 11:55 AM
  #31
XJ8JR's Avatar
This may sound crazy but you should also check your transmission mount. When it's wrecked, the transmission sits in an awkward position and can make all sorts of weird noises in conjunction with the driveshaft.
Old Jan 4, 2019 | 05:30 PM
  #32
DannyJ's Avatar
Transmission and engine mount are brand new...one month old. Thanks anyway, it's not crazy at all...
Old Jan 13, 2019 | 02:05 PM
  #33
DannyJ's Avatar
I have seen that back picture of instrument cluster
seems like there is a speaker on the right side so i suspect it may be the source of the whining noise i experience
Anyone knows if that's a speaker?
How difficult is to remove it to check?
Old Jan 13, 2019 | 02:18 PM
  #34
DannyJ's Avatar
Old Feb 27, 2023 | 03:08 AM
  #35
sweeper's Avatar
Originally Posted by Stuart S
I realize the need for privacy, but don't understand why some Forum members refuse to provide a general location such as city and state. I usually don't reply to them.
I don't understand why you need to know!
Old Feb 27, 2023 | 09:53 AM
  #36
Cee Jay's Avatar
That would be so more pertinent info could be provided to further assistance given to other members. Why would someone want others to suggest going to Edinburgh when they live in Seattle?
Old Mar 1, 2023 | 06:34 AM
  #37
guy's Avatar
guy
My shop uses a stethoscope… which seems more efficient then arbitrarily pick and replace.
kmiecmonster
Nov 21, 2011 10:44 PM
clubmia85
Jul 1, 2008 10:46 AM
happilute
Mar 9, 2008 01:15 PM
mobiledave
Jun 30, 2007 08:21 AM
macchiavelli
Apr 15, 2007 05:14 PM
