Whirring noise on engine off - normal?
Subscribe
Apr 30, 2025 | 06:35 AM
Hi
Wanted to confirm whether this sound is normal and what that might be:
need to turn the volume up a bit, constant whirring.
This is with engine off.
This is a friends XK but my does the same, both 5.0ltr N/A. I only noticed after he pointed it out.
Reply 0
Apr 30, 2025 | 07:20 AM
Probably the aspirator. Little fan behind the slotted area above your knee. Search this forum for ‘aspirator’, you’ll find several threads, like this one:
Aspirator Fan Noisy
Reply 0
Apr 30, 2025 | 07:45 AM
Reply 0
Apr 30, 2025 | 07:46 AM
Thanks!
Will try that and report back
Reply 0
May 1, 2025 | 07:03 AM
Brachacz:
I encountered the same sound when I first bought my 2008 Jaguar. I learned that it's a normal process and turns off a few minutes later.
I also learned it's best to put it in sleep mode "lock-it" and I can go 2-3 weeks with no battery drain and no trickle charger.
I will say that your fan sounds louder and less constant than mine. Maybe the fan needs a drop of oil to quiet it down a bit.
Rick
Reply 0
May 1, 2025 | 09:43 AM
Quote: I will say that your fan sounds louder and less constant than mine. Maybe the fan needs a drop of oil to quiet it down a bit.
Most likely it’s just dirty.
Reply 0
May 2, 2025 | 08:39 AM
Yes pull it out and clean it first. They get surprisingly dirty.
Reply 0
May 5, 2025 | 01:58 PM
Indeed it was quite dirty. After vacuuming , the noise is a bit quieter, good to know it isn't something serious.
After removing a screw, I didn't really like the idea of having to cut the foam to get the whole assembly out, don't really have anything to replace it on hand.
Of course while disassembling, I broke one of the plastic tabs keeping the fascia in place but I hope superglue will suffice.
Reply 1
Subscribe
Currently Active Users (1)
