Window in the Convertible top
Old Sep 13, 2018 | 08:30 AM
  #201
jimi727's Avatar
Originally Posted by ralfbrookes
I would like to pursue this option - what was name of the repair shop in Sarasota that did the stitch and reglue and did it work well and hold up over time?
RalfBrookes@gmail.com
text (239)910-5464
The shop was in St Petersburg, not Sarasota
I believe it was 'top of the Line Auto Interiors'
6767 Haines Rd N, St. Petersburg, FL 33702
Also , It didnt hold, if you see my last post or two, I am now looking at gluing it but I'm not sure I will be able to
As soon as I get time to attempt it
Old Sep 13, 2018 | 09:50 AM
  #202
Stuart S's Avatar
You CAN do it! It's really easy with the Suck 'N Clamps and Rhino Glue. Lots of posts here with tips and photos.
There's no harm in trying. You can't make it worse than it already is if you take your time, use masking tape, and do one small section at a time.
Old Sep 13, 2018 | 11:12 AM
  #203
110reef's Avatar
Originally Posted by 110reef
So I am curious now. Mine has separated on the outside, and I plan on gluing that back down. But what about the inside, does that need gluing too?
Stuart -
What are your thoughts on gluing the inside? is it necessary?
Old Sep 13, 2018 | 03:54 PM
  #204
amcdonal86's Avatar
I am also curious about the inside. Does this area actually detach??
Old Sep 14, 2018 | 10:24 AM
  #205
JackJohn's Avatar
If your are thinking about the headliner, it is held in place by a variation of hook and loop.
Old Sep 14, 2018 | 02:43 PM
  #206
110reef's Avatar
So the window is only held in place by a bead of glue between the window and the canvas top?
Old Sep 14, 2018 | 04:52 PM
  #207
Stuart S's Avatar
Stuart -
I glued the outer edges of the outside glass to the underside edges of the top, just like it was originally made. I didn't see where anything came loose on the inside. But maybe I don't understand your question.
And yes, an adhesive between the glass and canvas top is what holds the glass in place. I suspect that the OEM process heat seals the glass and canvas top together with an adhesive under pressure. While we DIYers can't replicate that process, Rhino Glue and Suck N Clamps does a decent job.
Old Sep 15, 2018 | 09:35 AM
  #208
fritzthecat's Avatar
110reef: I know what you're talking about with regards to the headliner - look at my post #186 https://www.jaguarforums.com/forum/x...0/#post1956882 especially pictures 1, 2, and 5. You can see it in those pictures. The inside headliner attaches to the top all around the window with a funky kind of nubby plastic velcro-like stuff. (That's the official technical term) Mine was pretty much all separated, but that's ok, that's what you want to get it out of your way while you do the repair. Then when it's all done and the glue is fully set, you just snap the headliner back in place and it's all good.
Old Sep 16, 2018 | 07:17 PM
  #209
amcdonal86's Avatar
Any idea if this rhino glue stuff works on the peeling dash issue as well?
Old Sep 17, 2018 | 08:24 AM
  #210
110reef's Avatar
Thanks for the replies. I glued mine yesterday. It was only a little separated along the right side. We'll see how well it holds up!
Old Sep 17, 2018 | 11:10 AM
  #211
Stuart S's Avatar
You should expect the rest of the glass to eventually separate from the top, so check it every day. When mine did, I just reglued that newly separated section. Third time's a charm, as I have now completely reglued the entire glass. It's not perfect, but it's not bad and beats buying a new top.
Old Sep 17, 2018 | 11:14 AM
  #212
110reef's Avatar
Agreed on all counts.
Old Sep 17, 2018 | 07:14 PM
  #213
amcdonal86's Avatar
How does it work as far as water penetration? Does the glue seal sufficiently?
Old Sep 17, 2018 | 08:52 PM
  #214
Stuart S's Avatar
Yes, it's waterproof if you apply a sufficient bead of Rhino Glue with no gaps, particularly along the bottom edge. Try and lift the edge and you'll see how tight it is. But just to be sure, give it the garden hose test. Wad up some paper towels against the inside of the top along the bottom edge under the glass and then spray the back window with a hose. If the paper gets wet, there's a gap in your repair.
Old Sep 17, 2018 | 10:18 PM
  #215
amcdonal86's Avatar
Maybe I missed this, but how long can the top be left partially open before it needs to be manually closed and reset?
Old Sep 22, 2018 | 12:41 PM
  #216
amcdonal86's Avatar
I'm working on this now. Seems to be going pretty smooth. I'm just letting each section cure for about 20 minutes before moving on. Once the last section is done I'll let it rest 1 hour without clamps before trying putting the top up.
​​​I also am repairing my rear defroster tab while I'm in there.
Old Sep 22, 2018 | 12:48 PM
  #217
amcdonal86's Avatar
Also, maybe this is obvious, but when leaving the top in a partially open position, do NOT leave the car in ACC mode. Turn it off. Otherwise, the car will eventually think there is a top malfunction and you'll have to go through the manual reset procedure. If you turn it off, the top seemingly can stay that way indefinitely
Old Sep 22, 2018 | 05:23 PM
  #218
Stuart S's Avatar
I did my repair with the top closed. I thought about leaving the bottom open a bit to relieve any tension on the fabric, and decided that when closed the top the tension might pull the top away from the glass again.
I realize that others have been successful doing the repairs with the top partially open.
Old Sep 22, 2018 | 05:33 PM
  #219
amcdonal86's Avatar
I think the main advantage of having the top partially open is being able to position the window from behind with one hand, but I agree. Once I closed the top some of what I had glued pulled away just slightly.
Old Sep 23, 2018 | 08:17 AM
  #220
amcdonal86's Avatar
Today it is raining and I have concerns about whether the window is watertight since the glue is the only thing sealing it from the elements.
