Window doesn’t drop when I open the door
Old Jun 10, 2024 | 03:09 PM
Dops's Avatar
Default Window doesn’t drop when I open the door
Guys, this feels simple but I can’t find anyone with the same fault. When my drivers door opens from outside, the window doesn’t always drop a bit, it’s about 50/50.
if I pull the handle harder it seems to be ok. Is there an adjustment?
if I open the door from inside, the window drops as normal.
I won’t even go into the fun of when there’s frost!
it it just the switch?
thanks
Old Jun 10, 2024 | 04:39 PM
XKDreams's Avatar
Have you done the window reset procedure?
- on each window run up, and hold the switch until,you hear a click. Then run down and hold switch until you hear a click.
Old Jun 11, 2024 | 12:44 PM
Dops's Avatar
Hi, thanks, tried it but never hear the ‘click’ . Will do it again. I’m thinking it’s a micro switch failing but to be intermittent is odd.
thank you for replying
Joexkr2001
US Northeast
Mar 2, 2022 04:25 PM
jlewis10
Jun 21, 2021 03:58 PM
MediaBobNY
Aug 11, 2018 07:37 PM
Hill2302
Nov 5, 2010 09:22 PM
garver
Nov 4, 2010 04:57 PM
