Window only goes half way up - RESOLVED
Old Feb 24, 2022 | 07:43 AM
CurtinUAE's Avatar
Default Window only goes half way up - RESOLVED
Picked up car from getting all new interior done and the passenger window only goes up half way. Shop said its probably jag software problem. I rember reading about wimdow reset so figured i could sort it.
so it goes down fine but stops halfway going up.
When its up halfway it still does to litlle drop and rise with door handle
Cant see how removing and replacing door panel could affect the window
Tried the window reset and battery reset
no change
Will try SDD scan tomorrow. 1st time to use it so a bit nervous
anyone seen this before?
Last edited by GGG; Feb 26, 2022 at 03:47 AM. Reason: Add 'RESOLVED' to thread title
Old Feb 24, 2022 | 09:09 AM
Cee Jay's Avatar
Yes, when the panel is removed and replaced incorrectly. Your shop messed it up. Make them fix it. Probably a misaligned cable, something out of a stop, holder, bracket or something. This does NOT sound like a software problem.
Old Feb 24, 2022 | 09:29 AM
CurtinUAE's Avatar
thanks thats what i told them i thought. They will make it right. I just hate the thought of having to drive to the industrial city in Abu Dhabi. Its like little bombay. Nerve racking
Old Feb 24, 2022 | 09:33 AM
If it drops fully and rises half way normally, it could be something resisting the glass movement in the guide rail and tripping the anti-trap feature. Alternatively, the lift motor could be misaligned on the drive although I can't think why anyone would need to interfere with this just to re-trim a door card.
Old Feb 26, 2022 | 12:37 AM
CurtinUAE's Avatar
Default Fixed
Fixed . The upholstery shop mistook the guide rail screws at bottom of door for panel screws and mis adjusted the guides by a couple inches .luckily i could see where they should be by grimy vs clean threads.
sailorbill
Jan 11, 2022 10:07 AM
TTG
Nov 8, 2018 04:47 PM
hicat
Jan 20, 2015 12:08 AM
brgjag
Sep 9, 2014 08:52 AM
