Wiring backup camera from trunk to cabin, 07 XKR convertible
Old Aug 28, 2022 | 09:02 AM
silvertonesx24's Avatar
Default Wiring backup camera from trunk to cabin, 07 XKR convertible
Searched and couldn't find any specifics, what's the most painless route from the license plate (through the harness) and into the cabin?
Old Aug 28, 2022 | 09:48 AM
Cee Jay's Avatar
Follow the harness to the inside part of the rear seat fuse block, then go under the seat and carpet and along the console and up to the TSD. No need to remove the console if you don't want, the cable can stick up under the edge and hold securely. I did take my bin out though, if I remember.
Old Aug 28, 2022 | 11:26 AM
Thanks, all wired up and good. All in all quite easy compared to other cars I've done this in. I found a red wire in the LHS of the trunk that I tapped into which seems to work fine.
Old Aug 28, 2022 | 06:07 PM
sweetsparkette's Avatar
I am considering doing this upgrade on my 07 XK. What camera did you purchase?
Old Aug 28, 2022 | 09:19 PM
Cee Jay's Avatar
You will need a modified version of SDD to enable the Park Assist Camera, as the dealers don't have access to the necessary option.
Old Aug 29, 2022 | 07:53 AM
I have V130 SDD & a Mongoose cable already. I had to recalibrate the seats when I first got the car. It’s has the OEM park assist on the rear bumper. Which version would I need? Thanks.
Old Aug 29, 2022 | 10:37 AM
Cee Jay's Avatar
Not so much a version, but a modified file to insert into your SDD program files. OR, find the ability (usually pay $100) to enter ENGINEERING MODE on SDD. Sadly, I don't have this info anymore since I've updated my SDD since I enabled my camera many years ago.
Either someone else can chime in here with the correct procedures, or maybe visit the SDD forum on this site for further information. I can't help any further. Good luck!
VetteOwner
Jun 25, 2023 05:38 PM
zockerede
Jun 14, 2021 09:08 AM
taimysho0
Nov 7, 2020 10:26 AM
tberry6686
Apr 8, 2018 04:40 PM
Leaper_Man
Dec 6, 2014 04:53 AM
