Wiring backup camera from trunk to cabin, 07 XKR convertible
Searched and couldn't find any specifics, what's the most painless route from the license plate (through the harness) and into the cabin?
Follow the harness to the inside part of the rear seat fuse block, then go under the seat and carpet and along the console and up to the TSD. No need to remove the console if you don't want, the cable can stick up under the edge and hold securely. I did take my bin out though, if I remember.
Thanks, all wired up and good. All in all quite easy compared to other cars I've done this in. I found a red wire in the LHS of the trunk that I tapped into which seems to work fine.
Either someone else can chime in here with the correct procedures, or maybe visit the SDD forum on this site for further information. I can't help any further. Good luck!
taimysho0
Nov 7, 2020 10:26 AM
