XK 2007 antenna replacement
Old Jun 9, 2020 | 03:39 PM
Sean W's Avatar
Thanks. Let's just post it here:
File Type: pdf
Old Apr 11, 2021 | 02:17 PM
andypreston's Avatar
Miles I know that you posted this antenna mast replacement 9 years ago but Thank You so much. I just bent the antenna mast on my 2007 XKR and searched all the forums and this was the only link that explained how to do it.
So thank you so much for taking the time and posting the procedure.
Andy Preston
Old Apr 12, 2021 | 12:37 PM
Qwikkitty's Avatar
Default XK 2007 Antenna Replacement
Andy Preston
Andy:
You're welcome! That's exactly why I posted it. Yes, we still have the car with a working antenna! Enjoy!
Myles
Old Dec 25, 2021 | 08:52 AM
Hockey_Steve's Avatar
Thumbs up
Myles
Allow me to add my thanks for posting the instructions.
I need to replace the bent antenna on our XK8 and I dreaded trying to remove everything inside the boot to get to the assembly.
Merry Christmas and Happy New Year to you and yours
Old Jan 3, 2022 | 09:04 AM
I purchased a replacement antenna mast from TheAntennaSource.com and used Qwickkitty's instructions to install the mast.
I was able to get the motor to grab the cable and retract it, but only to where there's about 6" still outside the assembly.
The length of the notched cable is the same as the old antenna, so I'm assuming there's no broken piece that would require disassembling the antenna housing to remove it.
Any suggestions so I don't have to visit a local stereo shop?
UPDATE
Local stereo shop says about two hours of labor @ $150/hour. I looked at taking the motor out, but there's a hydraulic pump right in front of it.
I'm starting to lean towards capping the hole in the fender and listening to Sirius and BT from my phone.
Old Jan 5, 2022 | 07:17 AM
guy's Avatar
guy
A couple of things.
1. if you’re certain that its installed properly, can you slightly “help” the antennae down during the retraction process? I believe replacement process is listed in the tech manual…. I’ll have a look shortly.
2. The sirius antennae is not the telescoping antennae.
3. I suspect properly removing the antennae and patching the hole will cost much more than the quote you’ve been given for installation.
Fwiw, the original antennae on my car works perfectly fine.
cheers.
Old Jan 7, 2022 | 12:24 PM
Originally Posted by guy
A couple of things.
That's what I've been doing with only limited success
I knew that 😉
I can receive FM signals with just the antenna barrel below the fender.
Thinking of just dropping the new antenna in, securing it and then pulling the fuse to keep it down at all times
cheers.
Lucky fellow. 😁🍺🍺
Old Jan 8, 2022 | 01:28 PM
  #28
Wink
A couple of things.
I can help it down to about 6" short of being all the way in. My guess is there was a piece of the old cable that broke off.
Yep. SiriusXM works fine
It could. Not sure I want to pay a couple of hours labor either at the dealer or a stereo shop to have an antenna that works since we rarely listen to AM or FM
cheers.
Well, aren't you the lucky one.
Old Jan 8, 2022 | 02:05 PM
kj07xk's Avatar
I guess if you don’t want to take the whole thing apart to check for a broken piece, you could take the new ‘cable’ back out, cut off six inches and put it back in.
Old Jan 8, 2022 | 03:38 PM
  #30
I've been thinking of that as a last resort.
The hydraulic pump in front of the antennae looks like a pain to remove.
Old Jan 8, 2022 | 04:21 PM
  #31
guy's Avatar
guy
yes, I put a toggle switch in the centre arm rest for that very reason… I don’t want the antennae extended while I’m using cds, usb or sirius.
Old Jan 10, 2022 | 08:21 AM
  #32
Default Success
I cut the cable and was able to get the antenna into place.
I pulled the fuse to keep it down and can still pick up some FM signals.
Old Jan 17, 2022 | 06:10 AM
  #33
twhumphrey's Avatar
Default XK 2007 antenna upgrade
Originally Posted by DpezXK8
I was wondering if there was a delete kit for the antenna and just replace it with what they use on the 08 and up. I believe they hide it under the back fin.
I was going to do exactly this on my 2007 XK, and I acquired the parts needed for it, but then I totaled my 2007 XK. If anybody wants to have the parts to make this upgrade send me a DM.
Old Jan 17, 2022 | 07:02 AM
  #34
Jagxk07's Avatar
Hi,
what I have done was replace the old genuine mast with an aftermarket new one bought from ebay and then as per the local dealership advice disconnected the antenna withiut removing the fuse.
Hope this might help you
Old May 19, 2023 | 12:43 AM
  #35
CA Jag's Avatar
I've got the same problem. Seller somehow jammed the damaged mast so it's not removable. One set of instructions shows pump removal thru the access port (trunk panels not removed) but includes removing the cover plate and disconnecting lines. Just 10mm nuts and several allen screws hold it in place. Wonder if removing trunk panels means I could simply move the hydraulic pump enough to access the motor? Comments appreciated!
Old May 19, 2023 | 01:12 AM
  #36
Jagxk07's Avatar
Default Antenna mast replacement
Normally by removing the trunk panel you should be able to reach the antenna motor so as to remove the mast and plastic thread and replace it with a new one. I think in the maintenance book there is a section and also there is a video in youtube with title"Jaguar Xk arial antenna change" posted 3 years ago which might be of your
assistance.
Old May 19, 2023 | 09:47 AM
  #37
Sean W's Avatar
Did you remove the grommet? I read your other thread where you mention only 1/2" of mast is showing. Is that with the grommet on or off? Replacement masts are much easier to do in situ. Remove the grommet, remove the nut underneath it, clamp a vice grip on the mast and pull up. There's nothing holding the mast in, except the nut under the grommet.
Old May 19, 2023 | 12:54 PM
  #38
CA Jag's Avatar
Grommet off, nut off. Twists easily but just will not slid out. Ran a cable down the tube. There's something jammed in there. Even so, the section of the mast that's left should slide out. Motor works but my inspect cable doesn't move.
Old May 24, 2023 | 12:21 PM
  #39
Qwikkitty's Avatar
Hockey Steve:
Just saw your post. You might just try removing the mast and repeating the install process. If you're certain there's no broken piece of the old mast in there, it should continue fully in.
Myles (aka Qwikkitty)
Old May 24, 2023 | 12:26 PM
  #40
Qwikkitty's Avatar
FYI, this old link stopped working. If you go further down this thread, you'll find a new permanent link to it, along with a more recent link I posted. Good luck!
ptjetpilot
May 11, 2017 01:27 AM
mbk2015
Jun 5, 2015 04:10 PM
Richy_T
Mar 20, 2012 02:33 PM
g11snyde
May 4, 2011 05:20 PM
