XK Convert – Roof Rattle
Old Jun 29, 2023 | 01:24 PM
wymjym's Avatar
Default XK Convert – Roof Rattle
I was reading about the latching motor in another thread and saw that there is a nylon gear.
My 2008 XK roof will rattle when I go over a large dip or rise, as if it is not secure.
It is secure. Could a worn nylon gear allow enough movement to permit this to occur?
wj
Old Jun 30, 2023 | 02:10 AM
Spitjag's Avatar
Hi, the nylon gear is within the gearbox and transfers the drive 90 degrees and provides two splined drives for the latching gear driveshafts. This gear being plastic wears or breaks and will prevent the hood latching or unlatching but assuming the motor drives ok I'm not sure why the hood should rattle as the mechanism tensions the hood and operates the latching hooks. It's easy to take the plastic shroud from the hood header, just a few screws and clips and you can see the mechanism move and maybe something has come adrift. I changed my gear for the brass type which are easily available and work well but they are considerably noisier in operation.
Old Jun 30, 2023 | 08:57 AM
wymjym's Avatar
thanks for the explanation.. I'll pull it apart in a week or so and have a look.
wj
wombat
May 25, 2025 01:04 PM
wymjym
Dec 30, 2022 07:37 AM
Martyp
F-Pace (X761) / C-X17
Sep 21, 2021 09:54 AM
cpuranik
Jan 28, 2011 12:31 PM
pantheraonca
Aug 7, 2010 12:49 PM
