XK wheel lock set
Old Feb 9, 2014 | 05:57 PM
bocatrip's Avatar
Default XK wheel lock set
What is the recommended wheel lock set for a 2010 XK? McGard? I have 19" factory rims.
Old Feb 9, 2014 | 06:07 PM
ndy.boyd's Avatar
I just purchased a McGard set on Ebay a few weeks ago. Very good quality and fit perfectly.
Old Feb 9, 2014 | 10:13 PM
Alljagz's Avatar
I purchased a set of OEM Jaguar wheel locks that came in standard Jaguar branded/labeled packaging. When I opened it the locks are stamped McGard. You can probably save a few bucks and just buy McGard.
Old Feb 9, 2014 | 11:14 PM
bocatrip's Avatar
Is it McGard Part# 24137?
Old Feb 10, 2014 | 12:28 AM
u102768's Avatar
I bought a set of these for my '07 XKR. They claim to be OEM (but don't match the accessory guide pictures) and have a little cap to cover the lock end so match the other wheel nuts:
JAGUAR XK 2006+ WHEEL LOCKING NUTS M12x1.5 from HEYNER | eBay
Old Feb 10, 2014 | 04:19 AM
ndy.boyd's Avatar
Yes. Here they are. I incorrectly stated earlier that I purchased these on Ebay. I actually purchased them from Amazon.com for $19.95.
Old Feb 10, 2014 | 08:14 AM
richzak's Avatar
Is the unlocking key to these wheel locks universal or made to go with each lock in the set? I don't have any experience using these.
Thanks for any response.
Old Feb 10, 2014 | 09:09 AM
ndy.boyd's Avatar
Each lock key is specific to the corresponding nuts. I've had these on my cars ever since 1988, when I came out from a movie with my wife and found my Pontiac GTO sitting on wooden crates with my very expensive wheels gone. The insurance covered the theft and the damage to the car, but as hard as I tried, I could never replace those exact wheels. The *******s didn't use the kick plates to lift the car and did damage to the rockers and undercarriage. Pissed me off to no end.
Old Feb 10, 2014 | 09:27 PM
bocatrip's Avatar
I just ordered them from Amazon.com for $25. I took one lug off and the picture makes the locks look longer than what I have, but the measurements of 1.5 inched deep and 3/4 inch across seems correct. Does each lock sit evenly with all the other lug nuts? I just don't want to have it sticking out. I love my symmetry!
Old Feb 10, 2014 | 09:36 PM
richzak's Avatar
Is the McGard #24137 standard for our Jaguar XK/XKR wheel studs?
Old Feb 10, 2014 | 09:52 PM
bocatrip's Avatar
I'll let you know that answer at least for the XK in a few days.
Old Feb 10, 2014 | 10:02 PM
ndy.boyd's Avatar
LOL. Yes, both the regular lug nut and the wheel lock have 1.5 inch spines. Your symmetry lives on.
Old Feb 10, 2014 | 10:09 PM
ndy.boyd's Avatar
Here is the McGard sizer.
Vehicle Application Guide
Old Feb 10, 2014 | 10:47 PM
bocatrip's Avatar
Thanks ndy.boyd..........now. can anyone tell me where I can get a nice set of valve stem caps to replace the grey plastic crap that's on there now?
Old Feb 10, 2014 | 10:52 PM
richzak's Avatar
Boca:
Here you go....
Jaguar Black Silver Growler Logo Tire Wheel Valve Stem Caps Set of 4 Genuine | eBay
For Jaguar Growler Car Wheel Tire Valve Air Dust Covers Caps Anti Theft Locking | eBay
Car Wheel Airtight Tire Air Valve Caps Cover 4 Pcs Fit for Jaguar Growler Black | eBay
Old Feb 11, 2014 | 09:21 AM
bocatrip's Avatar
Thanks Richzak. I wonder if they are plastic or metal. It doesn't say. I sent an email off to the seller.
Old Feb 12, 2014 | 02:26 PM
beh2010's Avatar
do not get the valve stem covers with locking option. No good after a while lock will mess up and you then have problem. The same goes for the wheel locks, after awhile they are no good and had a friend who had to weld the lock key to the nut to get the dam thing off. Also with wheel locks you can have a balance issue. I would not suggest any of them. As to the valve covers I got the growler caps and they where plastic but you cannot tell and they are weather reliable. Bought two sets also just in case one gets lost.
Old Feb 12, 2014 | 02:44 PM
bocatrip's Avatar
Thanks for the info. I have used the McGard wheel locks on every car I have ever owned without any problems whatsoever. I would not want to take a chance however unlikely to find my car up on blocks sans rims and tires. Hopefully, a professional thief does not want Jaguar rims. Maybe if anyone knew how hard they are to keep clean they will stay away from them!!!!!
Old Feb 12, 2014 | 02:52 PM
ndy.boyd's Avatar
Re:the wheel locks. You should never over tighten or use a power tool to tighten. Thats how the locking pattern can be damaged, resulting in removal problems with ongoing abuse. As for balancing issues. If you obtain the correct lock nut, specified for your make and model car, this is not even a remote likelihood.
Old Feb 12, 2014 | 10:33 PM
Alljagz's Avatar
I recall reading something about metal valve stem caps causing issues with the TPMS. Cracking of the stem or something. It is recommended to use plastic caps. Sorry I can't remember if that was a post on the forum or somewhere else. Could be wrong but I use plastic caps and they are fine. The purpose of the cap is merely to keep dirt out if the stem so a good plastic cap should be fine.
dsnyder586
Dec 29, 2024 07:39 PM
PMKimpton
Aug 3, 2019 08:22 PM
XJsc-guy
Nov 23, 2015 01:56 PM
tberg
Sep 7, 2015 07:32 AM
Whitnessmouse
Sep 4, 2015 11:09 AM
