XK/XKR Owners Map Link
Borrowing from the F-type group, I've set-up a ZeeMaps link where we can pin our locations using color pins. Like that group, I thought it might be something interested members could use to see who may be in their own area.
Here is the link:
https://www.zeemaps.com/map?group=2605285
The map key is "x150"
Here is the link:
The following 9 users liked this post by pwpacp:
autom8tr (02-06-2019),
Black River (02-06-2019),
kj07xk (07-07-2017),
LoudHogRider (07-07-2017),
mkmccoy (08-14-2017),
and 4 others liked this post.
Map Model Year by Marker Color
Here is the link:
Here is the link:
I also noted that markers are available in 30 colors. We can identify model years on the map if we use one color for each year. Using the color sequence in the dropdown box results in:
2007 - Red
2008 - Purple
2009 - Blue
2010 - Yellow
2011 - Green
2012 - White
2013 - Brown
2014 - Black
2015 - Grey
If you've already mapped your car, you may want to edit it. If you lost the edit link, just delete it and reenter it with the above marker color.
pwpacp -if you're the Map Administrator, you can insert a Map Legend that reflects the above colors. That will make it easier for new additions to choose the color for their year.
Stuart
P.S. The Moderator should make this a "Sticky".
The legend has been modified, just hope it is right. If not let me know and I'll take another stab at it.
Otherwise as Stuart indicated you can modify your color by year but may have to delete the balloon first then re-enter.
You know, as we pass through your area I will be on the lookout for you!
Received 1,897 Likes
