XKR Lowered H&R Suspension
Old Sep 11, 2017 | 03:45 PM
Freedom8675's Avatar
Default XKR Lowered H&R Suspension
Lowered my 2014 XKR over the weekend, might not be everybody's look. I think it looks nice and aggressive.
Old Sep 11, 2017 | 07:45 PM
sharx8's Avatar
Looks badass!
Old Sep 11, 2017 | 09:49 PM
peterv8's Avatar
Looks really good!
I'm thinking of lowering mine but maybe not as much as yours, half an inch less I would like .:-)
Old Sep 11, 2017 | 10:21 PM
steve_k_xk's Avatar
Pete go the Spires eibach 20mm lowering, the handling difference from the standard xk spring to the performance springs is exceptional.
Attached Thumbnails XKR Lowered H&R Suspension-img_20170829_153228.jpg   XKR Lowered H&R Suspension-img_20170829_153204.jpg
Old Sep 11, 2017 | 10:22 PM
Thanks, the H&R states it lowers 1.3 of an inch, Seems more. I also put the wheel spacers on, pushed out the wheels.
Old Sep 11, 2017 | 11:04 PM
ralphwg's Avatar
Too low for me. But each to his/her own. I would never get out the street that low!
Old Sep 12, 2017 | 06:36 AM
makecopies's Avatar
With some spacers it will be perfect!!
Old Sep 12, 2017 | 06:39 AM
Tervuren's Avatar
I feel the rear looks to be sitting almost lower than the front, it would look better with a small rake ankle the other way.
Have you considered changing the red brake caliper covers to black?
Old Sep 12, 2017 | 06:57 AM
it has the 15mm H&R spacers on it already
Old Sep 12, 2017 | 06:58 AM
Not a bad idea in black, I install the red, might be a bit much. I think black would look clean
Old Sep 12, 2017 | 07:13 AM
Jockster's Avatar
No way, red is loads better, links up with the rear light cluster and draws your eye around the car.
20mm spacers are perfect for the front, but 15mm is the limit on the rear I believe.
Old Sep 13, 2017 | 10:23 AM
multistrada74's Avatar
running the same set up and it's perfect in all ways.
Old Sep 13, 2017 | 12:57 PM
peterv8's Avatar
What kind och spacers do you use?
Where to buy?
Old Sep 19, 2017 | 06:56 AM
Jockster's Avatar
Where to buy?
I used H&R spacers, not sure where I bought them from though, sorry.......
Old Sep 19, 2017 | 11:34 AM
Cee Jay's Avatar
I'd consider spacers on the rear, but on the front they'd mess up the Scrub Radius.... and other geometry.
Old Sep 19, 2017 | 01:05 PM
SinF's Avatar
How do you drive over railroad tracks and parking lot speed bumps in a car this low? Also, how do you turn sharply at speed without rubbing front fender?
Old Sep 20, 2017 | 07:33 AM
Jockster's Avatar
You'd be doing pretty well to notice any difference on these cars, as long as your geometry is set up properly and your tyre pressures are good. I certainly haven't noticed anything other than my car looking a lot better!
Old Sep 20, 2017 | 01:48 PM
Does not rub at all in the front, I did get a bit of rubbing in the rear when taking a turn quickly. I had them "roll" the inside fender a bit and it went away. As for speed bumps, I go over slowly, otherwise I can bounce on top of them.
I get all kinds of looks in the car, it looks great
Old Sep 29, 2017 | 06:19 AM
benfbrown's Avatar
I agree with this. I put them on my XKR and am very happy. Firmer yes, but handling is also much improved.
Old Oct 2, 2017 | 01:37 AM
peterv8's Avatar
I have lowered a couple of Alfa Romeo's in my days and wonder if an XK is DIY?
Any special tools needed?
Is it a pain to get them off and on?
