XKR-S
Not arguing, just reasoning.
What side of the car has the master brake cylinder? Are you going to leave braking up to the passenger? I'd figure not, and the master cylinder gets relocated, and since there are brake lines associated with that component that those would also need to be moved, but that's problematic to rebend brake tubes, so replacements would be necessary.
The ABS pump is what controls all the 4 brake lines for all the 4 wheels. Mater cylinder gets relocated to the LHD side but the ABS pump doesn’t move. The only two brake lines that need to be replaced are the one from the master cylinder to the abs pump.
you don’t need to bend/make them as Jaguar and breakers sell this parts.
hope this explains
hope this explains
hope this explains
