XKR-S
Old Feb 8, 2026 | 08:04 AM
wymjym's Avatar
Good luck on this project.
How long do you think it will take to complete the conversion?
WJ
Old Feb 8, 2026 | 08:20 AM
Key Log's Avatar
WJ
once all the parts has arrived I believe a week or so to finish.
Old Feb 8, 2026 | 08:21 AM
wymjym's Avatar
WOW!
WJ
Old Feb 8, 2026 | 09:06 AM
Cee Jay's Avatar
brake lines don’t change the ABS pump stays in the same position, it only changes from brake servo to Abs......
What side of the car has the master brake cylinder? Are you going to leave braking up to the passenger? I'd figure not, and the master cylinder gets relocated, and since there are brake lines associated with that component that those would also need to be moved, but that's problematic to rebend brake tubes, so replacements would be necessary.
Not arguing, just reasoning.
Old Feb 8, 2026 | 11:50 AM
Key Log's Avatar
The ABS pump is what controls all the 4 brake lines for all the 4 wheels. Mater cylinder gets relocated to the LHD side but the ABS pump doesn’t move. The only two brake lines that need to be replaced are the one from the master cylinder to the abs pump.
you don’t need to bend/make them as Jaguar and breakers sell this parts.
hope this explains
Old Feb 8, 2026 | 12:39 PM
Cee Jay's Avatar
hope this explains
Exactly what I said. Replace some brake lines. Thanks for confirming my post, but it was unnecessary to do so.
Crobertrod
May 9, 2022 07:14 PM
StiggyMac
Oct 5, 2020 09:51 PM
01Silverstone
Dec 24, 2015 08:31 PM
xk.rs
Nov 25, 2013 04:17 AM
Cambo
Oct 10, 2013 06:43 AM
