You have to see this . WOW what a good deal
Old Nov 1, 2014 | 02:40 PM
sherbercars's Avatar
Default You have to see this . WOW what a good deal
Go to, wheels on ebay 181569086619
Old Nov 1, 2014 | 04:58 PM
richzak's Avatar
That's a "super deal", Bernie. Hope you sell them.
Have you listed them here on the forums "classified page"?
Old Nov 1, 2014 | 05:04 PM
mosesbotbol's Avatar
Wow! Someone on here was just looking for a set of wheels; well here you go! I'd be all over that if I still had my XK. 19" and easy to wash; exactly my one-two check list.
Old Nov 1, 2014 | 07:10 PM
Hi Richard, Yes I had them on here but no takers. But they will sell as I have removed the reserve, A good deal for someone for genuine Jaguar wheels.
Do's anyone know how to put the ebay ad on here to make it easy to bring it up, only 2 days to go.
http://www.ebay.com/itm/181569086619...619%26_rdc%3D1
Old Nov 1, 2014 | 07:32 PM
Bernie - I added the link to your post. That is indeed a sweet deal
Old Nov 1, 2014 | 08:29 PM
Thanks Steve. That will be better.
Old Nov 2, 2014 | 01:48 AM
CleverName's Avatar
Wish they were 18's......
Bummer, as it looks to be a good buy so far!
BOL
Old Nov 2, 2014 | 08:53 AM
Quebecjag's Avatar
Someone know if those wheels would fit on my 2014 xJL? Can find the specs of my XJL in the handbook!
Guy
Old Nov 2, 2014 | 05:30 PM
ralphwg's Avatar
Nice wheels, great condition, too bad they don't fit the 12 xk verts.
Old Nov 2, 2014 | 08:59 PM
BOL
18"on a 07 xk ?? I thought all the 150 where 19"/20". ??
Old Nov 2, 2014 | 10:20 PM
CleverName's Avatar
The '07 XK was offered with 18" (Venus) and optional 19" (Carelia) rims. Not sure the 20s were made available on an XK til the following year when they dropped the 18's for 19/20 options.
I know the 20s were available on the XKR in 07, so maybe we had all three.
Still wish I had a set of 18's to help refine the smooth ride of the XK. These short sidewall 19 and 20s make for a much rougher ride than necessary for a GT car...
Old Nov 2, 2014 | 11:15 PM
07XKJaguar's Avatar
My 07 XK came with the 20" Sentas as an option along with the little fender flaps.
Old Nov 3, 2014 | 10:34 AM
ndy.boyd's Avatar
The compatibility chart in the ad shows that these wheels will not fit a 2008 XK convertible. I'm curious as to why. I have '19's on my car now, so is the bolt pattern different on these wheels?
Old Nov 3, 2014 | 12:38 PM
Im sure they are the same.
Make Jaguar oem Jupiter.
Wheel size 19"
Bolt pattern 5 x 108
Hub 63.3
Front 8.5 offset 49mm
Rear 9.5 offset 31mm
Hope this helps .Thanks Bernie
Old Nov 3, 2014 | 01:15 PM
richzak's Avatar
Wheel size 19"
Hub 63.3
Those are standard Jag OEM sizes so the wheels that you have for sale should be an outstanding value for another Jaguar owner.
The sizes above were the same for my 2009 Jag XKR PE. The only difference is my wheels were 20".
Old Nov 3, 2014 | 03:21 PM
bocatrip's Avatar
I checked the compatability chart and it says that my 2010 XK Coupe is not compatable. I currently have 19" wheels on the car now.
Old Nov 3, 2014 | 03:40 PM
Check with the specs in my above post. I was of the understanding they are the same. ?
Perhaps someone on here could answer this .
Old Nov 3, 2014 | 04:14 PM
richzak's Avatar
As stated in my previous post above, Bernie's wheels are standard Jaguar OEM sizes, for bolt pattern and centerbore.
You can reference the following the website for the Jag XK/XKR sizes by year. There are plenty of other websites that will confirm the sizes also.
Here's an easy one to follow.......
Wheel-size.com :: Reference guide for car wheel and tire dimensions such as size, offset, PCD
The only difference that arises with any wheel is the offset or ET.
There is quite a range on the offsets for the Jag MY's.
The link to the above website should anwser any questions about fitment.
Offsets on wheels can be frustrating to figure out, but Jaguar brands have a wide variable in the offsets that can be used. The offset will create a wider stance or narrower stance once mounted on the car. Keep in mind that offsets are sized in mm's so the difference between offset sizes can be very minimal at best.
So the 5 x 108 Bolt pattern is found on all XK/XKR's 2007 to 2013 as well as the centerbore of 63.3 or 63.4. Only difference may be the offsets.
Hope this helps. For new wheels, Sherbercars OEM Jupiter wheels present a great value, however, I am not sure what his reserve is, and what his final bottom line price is. Never-the-less, if you use a 19" wheel, his is an outstanding choice and value.
Old Nov 3, 2014 | 04:35 PM
Thanks again Richard,( ONE MORE BID AND I WILL TAKE THE RESERVE OFF ) I dont use my car for the winter , so I dont need them , so I would I would like to see someone who can, than have them sitting there. Bernie
Here is another Specs sheet.
http://www.discountwheelwarehouse.co..._Referance.cfm
Old Nov 3, 2014 | 04:42 PM
CAN SOMEONE HELP. With the spec sheet address above to come up.
