XK120 XK140 XK150 1948 - 1962
LMA Brake fluid
Old Apr 29, 2018 | 03:05 PM
georgeryoung's Avatar
Default LMA Brake fluid
I'm just finishing up with a brake job on my XK120. I've replaced the shoes, turned the drums, installed new Wheel Cylinders all around. A car buddy told me to use LMA Castrol brake fluid. All I see listed is Synthetic Dot4 fluid. What am I missing on this? I've been told if I use the synthetic fluid it will cause problems. I'd appreciate any input that you members can provide me with. thanks, george
Old Apr 29, 2018 | 04:03 PM
Doug's Avatar
All brake fluid is synthetic.
Perhaps you're thinking of silicone brake fluid? It has mixed reviews/opinions.
Old Apr 29, 2018 | 08:54 PM
motorcarman's Avatar
Back in the 1970s/1980s I used to rebuild Jaguar Brake cylinders and people that used DOT 3 fluid would have problems with the seal swelling. The British used different seals than US manufacturers so it was important to use the correct fluid.
The US government regulated the specs for brake fluid and some did not meet regulations. Girling Green and some others were not available but CASTROL LMA (Low Moisture Affinity) did meet the specs.
That has been the 'go-to' fluid for all British cars except for Rolls Royce from the Silver Shadow onward (They required RR363).
I don't know if the modern seal kits are neoprene and the common fluids are compatible so I would recommend staying with Castrol LMA GT fluid.
Amazon Amazon
https://www.ebay.com/itm/Castrol-125...53.m1438.l2649
Good luck with your research and let us know what you find.
bob
Old Apr 29, 2018 | 09:36 PM
Doug's Avatar
B
I think present day replacement seals must be compatible, Bob. I used the LMA for ages but all the local stores stopped carrying it so I switched to other brands 12-14 years ago. I was a bit worried but actually haven't had any problems
andrewrichardson
Jul 22, 2013 11:10 AM
Brewtech
Oct 8, 2012 09:43 AM
benebob
Jul 23, 2010 03:40 PM
NMH1977
Nov 30, 2007 09:55 AM
