XK120 XK140 XK150 1948 - 1962
XK150 auto/starter problem
Old Mar 11, 2024 | 07:21 AM
Mike5150's Avatar
Default XK150 auto/starter problem
HI
I have a 1957 XK150 auto. For some reason the starter button will not kick in when the gearbox is in park. It previously worked OK! Battery is ok as are battery terminals and connections to starter button. Any suggestions where I start fault finding?
Thanks!
Old Mar 12, 2024 | 06:40 AM
jaguar38s's Avatar
First measure if there is 12V on the starter switch, and 12V on the other wire when switch is pushed in.
Next there is a switch under the dash, that is connected to the gear lever.
This enables you to start in P and N.
From here on there is 12v going to the starter relay under the hood.
Old Mar 14, 2024 | 12:44 PM
Mike5150's Avatar
Thanks for this. My thinking has led me to next check whether I am getting 12 v at the switch. I will work through what you suggest and let you know how I get on.
Thanks for your help
Mike
Old Mar 16, 2024 | 11:21 PM
Bill Mac's Avatar
It sounds like the start inhibitor switch has either gone out of adjustment or has failed.
That switch stops you from starting in any position except in neutral (N) or park (P)
Old Mar 19, 2024 | 07:29 AM
Mike5150's Avatar
Thank you for this. After testing the voltage at various points and much head scratching I found the start inhibitor and fiddled a bit with it and hey presto I had action!
So relieved!!
Old Mar 19, 2024 | 07:30 AM
Mike5150's Avatar
Thanks….I found it was the start inhibitor and once a. Fiddled with that irt all worked!
Thanks again!
Old Mar 20, 2024 | 08:02 AM
Bill Mac's Avatar
You are welcome. I have encountered this start inhibitor switch problem many times in early MK1 and MK2 automatic sedans.
Old Mar 20, 2024 | 08:05 AM
Bill Mac's Avatar
You are welcome. I have encountered this inhibitor switch problem several times in MK1 and MK2 sedans.
bjg625
Jul 12, 2022 06:46 PM
No Quarter
May 11, 2022 02:16 PM
Mikehill596
Jan 15, 2022 11:09 AM
Alphatrev
Feb 1, 2020 09:29 AM
dinerdash
May 15, 2013 07:30 PM
