How to clean MAF sensor
Old Aug 4, 2012 | 04:29 PM
LedZepplin's Avatar
Default How to clean MAF sensor
See attach photos this was on a Jag XKR 2001 54K miles
1/ Disconnect electrical connector and remove two phillips screws. Gently remove MAF sensor. (see pic 1)
2/ Spray CRC cleaner on the metal connectors below the bulb top until shiny clean 10-14 sprays should do it. Clean from both sides BUT DO NOT TOUCH ANY PART OF THE SENSOR!!! (see pic 4)
3/ From the top on one side you can see two other very small sensors inside the venture duct (see pic 5) spray 3-4 sprays on these to clean (DO NOT TOUCH THEM). Note most people do not know these exist I did'nt and did not clean and the MAFdid not work (performance restricted) once I clean these it worked fine.
4/ Clean the contacts (see pic 4)
5/ With compressed air blow out all the holes you can see as dust and crap builds up on the inside this should clean it. (se pic 5)
6/ Re-install MAF and reset then ECM i.e. disconnect the battery for 24 hrs. After connecting the battery reset windows (down hold 5secs up hold 5secs) and stereo settings.
I suspect step 3/ is not completed by most people so they end up buying a new one. I did but after taking a closer look and completing step 3/ my old one works also.
New ones can be bought for cheap from
Aliexpress.com : Buy Air Flow Sensor for (LNE1620BB=197408 0021) from Reliable Air Flow Sensor suppliers on HaoYang Auto Parts store
CRC spay I got on Amazon no Sales tax or S/H. (see pic 2)
Simon
Attached Thumbnails How to clean MAF sensor-maf-001.jpg   How to clean MAF sensor-maf-002.jpg   How to clean MAF sensor-maf-003.jpg   How to clean MAF sensor-maf-004.jpg   How to clean MAF sensor-maf-005.jpg
Old Aug 4, 2012 | 09:31 PM
joycesjag's Avatar
Thanks for taking the time to post up pictures and a follow through write up Simon.
I hope you don't mind I added the big pictures.
Old Aug 5, 2012 | 06:50 AM
steveinfrance's Avatar
Simon,
To do a quick hard reset
Disconnect batt ground lead
Touch ground lead to batt +ve for a few secs
Reconnect ground lead in one clean move.
Saves waiting for the module capacitors to drain down.
Old Aug 5, 2012 | 10:03 AM
Good post and very impressive cleanliness in the engine bay.
Old Aug 5, 2012 | 08:03 PM
Nice post and one for the FAQ "how to's" perhaps?
Nice and clearly shown, thanks
Old Aug 10, 2012 | 01:09 AM
uidyn's Avatar
Smile
The new ones also can buy from beltal.com which can pay with Paypal.
Old Sep 6, 2013 | 09:42 PM
xkr supercharged's Avatar
Could I just reset with my OBD reader?
Old Sep 6, 2013 | 09:57 PM
giandanielxk8's Avatar
That seems like an overly expensive way to clean it. I cleaned mine using q-tips cotton swabs and cotton ***** with nothing on them and a very tiny (hair trimmer cleaning) brush to remove the black gunk.
I inserted my MAFS back in place and secured it. I haven't gotten the restricted performance message nor a CEL ever since. Is the MAFS cleaner spray really necessary?
Old Sep 7, 2013 | 08:44 AM
Jon89's Avatar
The MAF sensor spray cleaner may not be necessary, but it is certainly safer than risking damage to the sensor by touching/rubbing it. All three of our vehicles have MAF sensors that periodically need cleaning, a spray can of MAF sensor cleaner will last me for years, so it was a no-brainer to go ahead and purchase a can and just keep it on one of my garage shelves until needed....
Old Sep 7, 2013 | 01:36 PM
RaceDiagnostics's Avatar
Avoid using oiled filters and the cleaning requirement will be much reduced, and acurate reading of air flow will be enhanced.
Old Sep 11, 2013 | 11:10 AM
Rovinghawk's Avatar
I use q-tips with a little isopropyl alcohol on them (leaves no residue). Cheap & works perfectly, needs no force.
It's fine with a very steady hand & gentle touch but I wouldn't recommend it to anyone who's not totally sure they can do it.
Old Jan 25, 2014 | 10:32 AM
Oeiemans's Avatar
Simon
Thanks for the excellent instructions! Saved me on repairs on my 2001 xkr. Symptoms left 18-22 and restricted performance bank 2 lean.
Regards Happy Jagged
Old Jan 25, 2014 | 10:39 AM
Oeiemans's Avatar
Simon
Sorry not left but LTFT in %...
Old Jun 3, 2020 | 12:12 AM
DarcySmith's Avatar
This is an old thread with not the greatest pictures but exactly what I needed to tackle the P0172 and P0175 restricting performance on my 2000 XKR. On inspection my new to me Jaguar had a dirty air filter and perhaps dirty MAF. I purchased a new air filter for $13 dollars and would've purchased a MAF from NAPA Auto Parts except they wanted $400 dollars for a refurbished unit! MAF sensor cleaner to the rescue and all codes are cleared and have not popped up again in a short interim drive. Hopefully won't pop up again in the near future.
Thank you to everyone that ever posted a "how to" thread. I expect to be very grateful!
Sincerely, Darcy
Old Jun 3, 2020 | 08:36 AM
mhminnich's Avatar
If it does come back, clean it again. It took me three tries at cleaning before the code really went away.
Old Jun 4, 2020 | 01:24 AM
zray's Avatar
^^^^^^^^^^ +1
my experience as well. Even though I cleaned the sensor throughly each time, It took 3 times before proper
operation was achieved.
Z
Old Jun 4, 2020 | 02:05 AM
DavidYau's Avatar
Darcy - thanks for your positive feedback on an old thread. This is what makes the Forum an interesting place to visit.
I use exactly this procedure with the MAF Sensor spray - it's now part of my annual service - oil service, air filter change, MAF sensor clean, fuel filter change, plus I clean some of the easier to reach ground electrical body contacts, and clean and condition the leather interior. Every time I take the wheel liner off, I also lube the upper A arm fulcrum bolt. Don't want that long bolt binding again.
MAF spray is cheap, and as Jon89 said, I just keep it on the shelf (lasted 2 years so far) for both my Jag and L322 Range Rover).
Old Jun 4, 2020 | 06:25 AM
Jon89's Avatar
I clean the MAF sensor every 20,000 miles or so. Still running the original factory Denso MAF sensor with no issues....
Old Jun 4, 2020 | 09:27 AM
fmertz's Avatar
Also, double check the condition of the o-ring at the base of the sensor. It missing, it seems to create a bigger air leak than one imagines.
Old Nov 21, 2022 | 01:32 PM
Johnnyb60's Avatar
WOW I just learned about the hidden wires up inside the MAF after all this time, and a short spin already has avg mpg readout bumping up against 20 (US gallons). Who knew? I've been averaging like 13 mpg and wondering wtf? I think this might've done it. And yes, spray. It says in like 15 different places DO NOT TOUCH.
silkcat
Jan 18, 2025 04:29 AM
xjrjag
Oct 24, 2024 03:09 PM
mrplow58
Jan 21, 2024 05:53 AM
caveforce
38
Nov 16, 2015 10:19 AM
jaaag
Sep 11, 2015 12:53 AM
