Need help asap ! Cant open trunk Battery dead
Old Apr 27, 2012 | 07:16 PM
dad2twins's Avatar
Default Need help asap ! Cant open trunk Battery dead
Ok,so my battery was bad so I disco'd it to go get another one. Closed the trunk -not thinking and now I cant get in the trunk. I only have the 1 GREEN key! Any suggestions?
Old Apr 27, 2012 | 07:20 PM
Check the FAQ's for Paul Pavlik's guide on 'Dead battery and can't open the boot to jump start?'
Old Apr 27, 2012 | 07:32 PM
vettegood's Avatar
You should let us know the type of Jaguar you have! They are all a bit different.
Since you are on the XK8/XKR threads I will assume you have one.
Use your key (black color)in the rear XK8/XKR emblem on the right side of rear end by the taillight and I believe you will find a key hole in the middle of the X and K of the emblem, X*K8 or X*KR.
Look with flashlight not easy to see if you do not know it is there.
Good luck.
Old Apr 27, 2012 | 07:37 PM
dad2twins's Avatar
Sorry,I have a 2001 xk8 . Yes,I found the key hole in back,but it did not turn. Would spraying a lubricant do any good?
Old Apr 27, 2012 | 07:42 PM
WhiteXKR's Avatar
Under the hood, connect the battery (+) to the to the bolt under the rubber cover at the fusebox, and (-) to the chassis, as shown below with a set of jumper cables. Take care not to short the cable. Then open the trunk using the button. DO NOT START THE CAR THIS WAY.
http://i127.photobucket.com/albums/p...Rengine40c.jpg
Thanks to Paul Pavlik for this and GGG for the reference above..
Old Apr 27, 2012 | 07:52 PM
dad2twins's Avatar
I was just coming back to ask that very question - where's the "jump point" under the hood?
David
Old Apr 27, 2012 | 08:01 PM
WhiteXKR's Avatar
It is a 'charge point'. If it is used as a jump point damage may be done to the vehicle. The wiring in that area cannot handle starting currents.
Old Apr 27, 2012 | 08:05 PM
dad2twins's Avatar
Thanks for the advice. Now if it were light out i could finish and move on to the next issue....... why it did not turn over or attempt to?
Old Apr 27, 2012 | 08:09 PM
vettegood's Avatar
The green key is for valet, won't let you in trunk or glovebox.
So the next best idea is WhiteXKR's jumping the car via the engine compartment. the bolt under the rubber cover is on the driverside about 6 inches behind and 4 inches to the right of the red oil stick handle. The bolt is on the front left corner of the black fuse box on drivers side engine compartment .
Take your new battery and use jumpers place the positive on the bolt and place the negative on the chassis of the car. And that should get 12 volt power to the system and push the trunk button and disconnect right away.
Old Apr 27, 2012 | 08:17 PM
WhiteXKR's Avatar
The credit goes to Paul Pavlik for the original post and illustration on the subject.
Old Apr 27, 2012 | 08:24 PM
dad2twins's Avatar
ok,but thanks for ya'lls time!
David
Old Apr 28, 2012 | 10:23 AM
dad2twins's Avatar
OK ,got in trunk,car started and now have "TRANSMISSION FAULT" code doesnt shift gears. Still have the same old battery. could this be the issue. Ran fine before dead battery.
also while I was attempting to sart the car before locking trunk,it was throwing weird codes.....now that it's started only the Transmission code. hope this helps some.
Old Apr 28, 2012 | 11:07 AM
steveinfrance's Avatar
Did you charge the battery? If so how?
If the battery seems good then try disconnecting the negative lead from it, touching it on the positive lead for 30 secs then reconnecting the negative lead to the battery.
If it works you'll need to 're-train' the windows.
Check you've got a 4 digit radio security code BEFORE YOU DO THIS!!!
Old Apr 28, 2012 | 01:24 PM
I thought your original problem was a dead battery? Discharged or dead batteries cause all kinds of problem codes. The battery needs to be fully charged or replaced and the codes cleared.
Is there some detail we're not hearing here such as the vehicle hasn't been started in a long while or it had other issues before the flat battery?
Old Apr 28, 2012 | 02:25 PM
+1 to Graham
Old Apr 28, 2012 | 03:23 PM
dad2twins's Avatar
Man these cars are more sensitive than women......turns out cleared codes and charged battery and all is good for now.?
Thanks again!
Old Apr 30, 2012 | 12:50 PM
NeilJones's Avatar
Exciting, isn't it, this Jaguar ownership?
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
mbergen
Oct 23, 2019 10:26 PM
martybmw
Apr 2, 2016 04:55 AM
prettydaim
Sep 7, 2015 05:16 PM
