What code should a leaking intake manifold gasket produce?
Old Nov 4, 2014 | 10:40 AM
seawind's Avatar
Default What code should a leaking intake manifold gasket produce?
I have a check engine light w/intermittent restricted performance (restricted performance seems to happen when the vehicle is slowed down at stop lights not normally when it's up to speed), code p0171. Mechanic diagnosed it as a leaking intake manifold gasket but I'm thinking it might be a miss diagnosis. Wouldn't a leaking intake manifold gasket produce both p0171 + p0174 if not an additional code along with them?
Thanks for the help
Old Nov 5, 2014 | 03:20 PM
JagV8's Avatar
Depends how big the leak is, where it is, and how long you leave it to see if it also flags P0174.
I wouldn't leave it as running lean is a bad idea! Just fix it
Old Nov 5, 2014 | 04:07 PM
mjlaris's Avatar
Yes, having been in this situation, you will get the left bank and/or right bank lean codes (P0171 and P0174). They'll come in at city speeds but will clear after 20 or 30 minutes of hwy driving.
Mark
Old Nov 7, 2014 | 07:07 PM
Beav's Avatar
Lean codes left unrepaired will cause the ECU to compensate by enriching the fuel mixture which will eventually lead to catalytic converter overheating and damage/failure. Then there's the extra fuel $$ spent, the washing of oil from the cylinder walls... The larger the air leak, the more fuel added, the quicker the issues arise. Just trying to point out that foot dragging on this repair isn't a good idea.
Just call me little Merry Sunshine. ;-)
clubairth1
30
Sep 3, 2025 04:38 PM
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
cissdm
May 3, 2016 06:02 AM
rachelstr
Sep 3, 2015 12:59 PM
