$457 to replace a front wheel bearing on a 97 XK8, does that seem fair?
Old Mar 19, 2013 | 01:43 PM
xenophobe's Avatar
Default $457 to replace a front wheel bearing on a 97 XK8, does that seem fair?
What the title says...
I know what I think, what about you?
Old Mar 19, 2013 | 01:55 PM
marktmv's Avatar
About $60 more than I paid, after taxes. But I think early gen bearings are a bit more expensive.
Old Mar 19, 2013 | 03:06 PM
RJ237's Avatar
If you do a search on the subject, you'll find that it can take several hours, so as much as it hurts, we just have to live with it.
Old Mar 20, 2013 | 04:30 PM
MRomanik's Avatar
Veteran: Air Force
Had to have hub & bearing replaced last yr when wheel stud was stripped by tire mechanic. It was $998.50. The bearing was $94.11 labor was $267.30.
Glad I didn't have to pay for it.
Old Mar 20, 2013 | 04:38 PM
Brutal's Avatar
Originally Posted by mromanik
had to have hub & bearing replaced last yr when wheel stud was stripped by tire mechanic. It was $998.50. The bearing was $94.11 labor was $267.30.
Glad i didn't have to pay for it.
and that is why i have spare studs taken out from old hubs i replace. That way i can just charge a customer a small amount to pull in a new stud. And to the op yes thats about right. Just hope the hub isnt eaten into by the bearing as youll have to replace that too then. Then i take the old hubs, weld to pipe, get some spare wheel nuts, and center cap and hang old Jaguar wheels from them cemeted into the ground for garden hose hangers. some of the nicest, most expensive hose hangers youll find
Old Mar 20, 2013 | 04:39 PM
xenophobe's Avatar
Ok, ended up the rear hub needed replacing too. Changed 2 headlight bulbs rear hub and bearing. Total was $1050.
I'm thinking a dealership wouldn't have even charged as much....
Old Mar 20, 2013 | 08:30 PM
Fedoraja1's Avatar
#1: Get a Ford Windstar bearing. Same thing, 1/5 the price.
#2: Hard work but can be done in house. I used a mechanic. I bought the necessary tool.
Old Mar 21, 2013 | 03:12 AM
Frog's Avatar
My UK Jaguar dealer charged me £250 (+/- $380) + 20% VAT just for the labour. I had already purchased the bearing separately.
Old Mar 21, 2013 | 10:21 PM
chopr's Avatar
Not the easiest of jobs. Price sounds pretty fair to me, figuring around $100/hr labor these days (if not more...)
Old Mar 22, 2013 | 02:14 PM
xenophobe's Avatar
It's not easy to toss old hub put a new bearing in a new hub and charge $870 for it?
Old Mar 23, 2013 | 10:38 AM
Gator Blue's Avatar
I had passenger side bearing replaced. $175.00.
Old Mar 24, 2013 | 01:59 PM
Jen & Neil's Avatar
It sounds fair, I am a tech for a living, I hear horror stories on what shops charge everyday. I also changed both my front bearings last year, parts were $140, it took over 2 hours, busted knuckles, an improvised abs ring tool, many swear words and a sense of a job well done at the end of it!!
Old Mar 25, 2013 | 12:04 AM
H20boy's Avatar
You do all your work at the 'office' or do you maintain your own press and other large manly tools in your garage?
Old Mar 25, 2013 | 02:25 AM
XKRacer's Avatar
It really does depend on how easy things come apart, I allow 2 hours a side but have spent much longer
Old Mar 25, 2013 | 08:12 AM
Jen & Neil's Avatar
I am lucky enough to be the tech/instructor at the Auto Skills Shop on Holloman AFB, so all the manly stuff is there!
BrentGardner
29
Dec 16, 2024 12:13 AM
philwarner
Dec 6, 2021 07:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
JaguarXKR
Sep 6, 2015 11:47 AM
