97 XK8
Its been a while..(was caring for son on Hospice)
Drove the hell out of the car this past year, its been a pleasure, outside of a few quirks( loose rear view mirror stabilized with bits of old credit card for now).
While detailing the car today, I noticed that the passenger side headlight doesnt seem to be seated like the drivers side .which is pretty close to flush to the car. The rubber seal edge of lamp , ( towards wheel) is protruding a bit. Is this a pricey thing to fix or some (please God) easy do-it-yourself fix?
Advice, suggestions ?
Its 3 bolts .2 easy on the top left and right but the third is under the wing ...wheel off ,pull back the plastic liner and its a pig to loosen. May have been removed and left out which is what I would do. Take out the two easy ones and see if you can push it back into place etc then tighten.
Good to know
.!Thanks!
