‘97 XK8
Old Jan 25, 2024 | 09:21 PM
Rosevillesister's Avatar
Default ‘97 XK8
It’s been a while..(was caring for son on Hospice)
Drove the hell out of the car this past year, it’s been a pleasure, outside of a few quirks( loose rear view mirror stabilized with bits of old credit card for now).
While detailing the car today, I noticed that the passenger side headlight doesn’t seem to be seated like the drivers side….which is pretty close to flush to the car. The rubber seal edge of lamp , ( towards wheel) is protruding a bit. Is this a pricey thing to fix or some (please God) easy do-it-yourself fix?
Advice, suggestions…?
Old Jan 26, 2024 | 03:04 AM
Pistnbroke's Avatar
Its 3 bolts .2 easy on the top left and right but the third is under the wing ...wheel off ,pull back the plastic liner and its a pig to loosen. May have been removed and left out which is what I would do. Take out the two easy ones and see if you can push it back into place etc then tighten.
Old Jan 26, 2024 | 08:01 AM
There’s always that bolt, connector that is in a crazy hard to reach place. Thank you! I’ll see what my nephew can do. You guys are the best.
Old Jan 26, 2024 | 01:32 PM
Pistnbroke's Avatar
I can tell you those lights are crap. The only way you will make them good is to fit 55w HID bulbs to both dip and main
Old Jan 26, 2024 | 04:05 PM
Default Adding this info
Good to know….!Thanks!
XK8BILL
Jun 26, 2022 09:20 PM
Isoruku
Nov 6, 2021 04:57 PM
perrymik
Feb 19, 2014 10:54 PM
hawkeye
Nov 19, 2013 12:44 PM
