rolling down the road, I have a bird chirp somewhere in the dash. Do I have to pull the dash out to find and tighten something? ...Obviously hoping someone has experience with this issue and this is not a belt chirp. It chirps because of vibrations and bumps, so something is loose.
I have read about this problems from a number of people. Try a small piece of rubber between the front of the dash and the windshield. No one has given a good explanation of what is loose but as far as I have read the only recommendation is to remove the entire dash assembly and carefully reassemble it.
I've moved your post from the General Tech section to the model specific XK8/XKR section for better response.
check the upper shock mounts for crumbling foam - mine made an insane chirp that sounded like it was coming from the dash when they disintegrated due to metal-metal contact.
I have new ones purchased that I haven't installed... next on the list of to do!!!
check the upper shock mounts for crumbling foam - mine made an insane chirp that sounded like it was coming from the dash when they disintegrated due to metal-metal contact.[/QUOTE]
The defroster vents at the front edge of the dash tend to warp from the heat and lightly vibrate against the windshield causing that annoying sound. I put a small piece of silicone rubber and the noise dissappeared.
Likely the shock mounts but could also be the cross brace struts - one of mine had worked loose. You'll need to remove the wiper blades and panel underneath to check.
Had same problem with my 01 XKR, very irritating. Drove a couple thousand miles that way. Squak in dash -windshield area. My problem was outer windshield moulding rubbing in the corners. A small piece of rubber tape in contact areas took care of problem. Also had a similar noise on 98 XK8, the old piece of matchbook cardboard trick between the upright wood grain and console woodgrain took care of that. Do they still make matchbooks?
