01 xkr window issues
Old Mar 30, 2012 | 11:45 PM
Green01xkr's Avatar
Unhappy 01 xkr window issues
Hi,
Noticed another issue with my GreenHulk while waiting for valve cover gaskets to arrive: every time i touch the driver side handle window goes down about an inch or so. Car has been sitting about 2-3 months now while i am trying to fix the misfiring problems..Its pain in the butt...
Any ideas why this window keeps dropping?
Thanks,
Old Mar 30, 2012 | 11:57 PM
K.Westra's Avatar
This is usually a sign of reduced voltage or if the battery has been disconnected. You simply need to reset the windows. Put the window all the way down and hold the switch down until you hear an almost inaudible click. Then put the window all the way up and again hold the switch until you hear an almost inaudible click. Voilą, fixed. You will probably have to do this to the passenger side window also.
Old Mar 31, 2012 | 12:04 AM
Green01xkr's Avatar
Will give it a shot tomm.
Thanks,
Old Mar 31, 2012 | 06:47 AM
WhiteXKR's Avatar
...and charge your battery. Car batteries die young when kept in a low state of charge. The low battery may trigger all sorts of puzzling faults in the car also.
Old Mar 31, 2012 | 08:03 AM
steveinfrance's Avatar
Do you mean the window drops (as it should) when you open the door but doesn't go back up ?
That's a door microswitch problem
Old Mar 31, 2012 | 08:12 AM
Green01xkr's Avatar
Yes.. Even with the door closed, every time i touch the handle it keeps dropping down... does not go back up..ever
Ill try the reset method, but i found some treads about the microswitch and crazy door handles that think the door is always open..
Old Mar 31, 2012 | 08:15 AM
david55838's Avatar
What he said. Charge your battery (or replace) first.
Old Mar 31, 2012 | 09:00 AM
If it's the microswitch you won't get a 'Drivers Door Open' warning with the door open.
But listen to the others re a reset first.
Old Mar 31, 2012 | 10:14 AM
Gus's Avatar
Gus
Recharge your battery and do the reprogram. If that does not work spray a little (do not saturate) WD40 in and on the locking mechanism and work the door. The latch is often forgotten and never lubricated.
Old Mar 31, 2012 | 10:42 AM
Green01xkr's Avatar
Love this forum... You guys are awesome
Old Mar 31, 2012 | 01:09 PM
Green01xkr's Avatar
Problem sovled... Simple reset..
Thanks fellas,
Old Apr 1, 2012 | 02:58 AM
Thanks fellas,
There you go - I've learned something as well.
Thinking about it last night I was a**e backwards - if it's the microswitch the window doesn't lower when you open the door so you can't shut the door 'cos the window bangs into the door seal.
Glad I didn't take a bet on it - and glad it's fixed.
Old May 9, 2012 | 04:03 PM
macuser's Avatar
You guys are awesome Who knew it could be tant easy!
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
Skeeter
Sep 17, 2015 08:15 PM
obwoodie
Sep 3, 2015 07:45 PM
colorancher
Sep 3, 2015 02:29 PM
