02 XK8 Disaster after new battery
Old Jan 16, 2025 | 12:37 PM
terryo505's Avatar
Default 02 XK8 Disaster after new battery
Recently replaced with premium battery after the old battery which i keep on a float charger died after an extended power outage after hurricane. After which the info readout indicates every error, I believe, it is capable of indicating.None of which would I consider accurate. Licked in park, but will start and drive fine if i go to neutral after 1st ignition pos, but if i go to park pos after started it will lock, in other words It starts, runs and drives perfectly. all gauges are pegged and odometer increases several thousand miles each drive cycle. P1638 is the engine code from my reader. Does this sound like the instrument cluster issue or a wiring/grounding issue? I am fairly handy with auto repair and somewhat know my way around a volt meter. I have checked all fuses excpt those in the luggage compartment fuse box.
Old Jan 17, 2025 | 03:13 PM
JagV8's Avatar
Got the ZF HP26 trans? Could a bolt be loose/missing? Under car, side of trans, 2 8mm hex bolts hold the shift cable to the trans.
Old Jan 17, 2025 | 03:18 PM
RJ237's Avatar
The 02 US version has a 5HP24.
Old Jan 17, 2025 | 03:19 PM
RJ237's Avatar
The 02 NA version has the 5HP24.
Old Jan 17, 2025 | 11:38 PM
baxtor's Avatar
Have you tried retracing your moves. Disconnect battery, allow systems to shut down and start again. Also ensure the battery is fully charged.
I believe the error code relates to CAN token missing, possibly just a hiccup related to your battery change.
Terrazen
Mar 29, 2024 09:04 PM
Badger2021
Mar 21, 2022 04:31 AM
Raver83v2
Aug 9, 2020 03:21 PM
hlgeorge
Dec 3, 2016 01:43 PM
