02 XKR P0400: EGR, rough idle, "engine stall"
Old Sep 19, 2011 | 02:12 PM
pomosv's Avatar
Default 02 XKR P0400: EGR, rough idle, "engine stall"
I had an orange engine light and car seems fine, with the exception of a "rougher" idle. I drove around with it and once or twice the idle dropped too low and I got the "engine stall" message.
Code reader says P0400 - Exhaust Gas Recirculation flow. I read something on here about an EGR valve?
Anyone had this issue before? Thanks
Old Sep 19, 2011 | 11:08 PM
H20boy's Avatar
I remember one member getting a EGR error related message, he had to replace his EGR valve. IIRC, it also was a DIY but a real bee-otch. It too was on an XKR also...what's up with your EGRs that puts them under so much stress?
Old Sep 20, 2011 | 12:51 AM
pomosv's Avatar
Just an update, saw another thread on here about an XJR owner that removed his EGR valve (just under the TB) and cleaned it, apparently it tends to get clogged.
I looked under the TB and you're right H20, looks like a big PIA to get to. So I got a bottle of carb cleaner spray, took off the intake tube, and with the engine running opened up the butterfly on the TB and sprayed a moderate amount of carb cleaner all around and down the TB. I guess that seemed to do the trick - idle is noticeably smoother (although I still feel it's maybe a little rougher than it should be) and once I reset the code it hasn't come back after driving all day.
Fingers crossed as I watch it over the next few days...
Old Sep 20, 2011 | 11:11 PM
pomosv's Avatar
Problems again...
P0400 disappeared after I cleaned the TB a bit and cleared the code as mentioned above.
What followed was a jag specific code, something along the lines of "registering too lean". I figured it was because of the carb cleaner I used and just reset the code.
A day later, once again a check engine light, now P0133 & P0153 O2 sensor circuit slow response - Bank 1 & 2 Sensors 1. Again, car seems to be driving fine.....I'm lost...
Old Sep 21, 2011 | 12:11 AM
avos's Avatar
Better double check if there are no air leaks, the p0400 and the lean codes certainly point in that direction. So check that the EGR unit sits tightly on the elbow and that the pipe between the egr and exhaust is not leaking. The p0400 only shows if you have gotten the error in 2 consecutive drive cycles, so could reapear later again.
Not sure why both upper O2 sensors show an issue now though.
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
Beardy
Sep 18, 2015 10:00 AM
XFR_Gold
Sep 2, 2015 12:24 PM
TC Johnson
Sep 2, 2015 09:30 AM
