03 needs to be louder
Old Jun 5, 2015 | 11:25 AM
brgjag's Avatar
Default 03 needs to be louder
Got the stock exhaust on it. What is a good way to make it growl a little more. Can it be as easy as removing the mufflers before the rear end, or the ones at the back of the car. I don't loud loud, but more of a note than it give now,
Old Jun 5, 2015 | 05:51 PM
SteveJacks's Avatar
There are lots and lots of threads about this already, search and you will find
Old Jun 5, 2015 | 06:10 PM
michaelh's Avatar
+1
I generally prefer a car that understates its capabilities, as opposed to one adorned with spoilers, stripes, go-faster wingnuts and racing headlamp bulbs, but...
IMHO there is nothing that comes close to the melody of an on-tune V8 either burbling at tickover or singing when the loud pedal is pressed. The X100 in all its standard guises mutes this to a whisper.
Never thought I'd ever say 'my car is too quiet'
Mike
Old Jun 5, 2015 | 09:10 PM
max224's Avatar
Check out the exhaust systems from Mina Gallery. I put on their system that includes rear resonators (and is about as pretty as exhaust systems get) and also installed their intake and filter. Gives a nice, low rumble at low rpm's, and doesn't get obnoxious at high rpm's. The car also seems to have a better throttle response and a bit more power, but that's a subjective opinion. As mentioned, there are also numerous threads on the subject.
Old Jun 5, 2015 | 11:00 PM
Jandreu's Avatar
I removed the before axle resonators and added a Mina intake. Sounds good at WOT but only a slight rumble at idle and cruzin. I'd like a little more sound at idle and mild cruzin so may delete the center and add a H crossover. Had an opertunity to hear phils's car with this set up and it may be a little to loud when WOT but normal and idle sounded just about right.
inactualis
Oct 2, 2015 11:13 AM
LondonXK8Boy
Sep 14, 2015 08:26 AM
Phil G.
Sep 12, 2015 07:42 AM
martybmw
Aug 31, 2015 10:15 PM
kcamacho11
Jun 27, 2008 08:52 PM
