06 XK8 Sidelamp replacement?
Old Apr 12, 2022 | 08:50 AM
KRT's Avatar
KRT
Default 06 XK8 Sidelamp replacement?
the sidelamp is cracked and the light doesnt work. it looks like i can access from the wheel well if i am correct, pop out and replace or not so easy? thanks
Old Apr 12, 2022 | 01:36 PM
rothwell's Avatar
There are some pics in my working thread here that might help.
Old Apr 13, 2022 | 08:54 AM
KRT's Avatar
KRT
thanks for the insight, so where did you access the sidelamp through the wheel well?
Old Apr 13, 2022 | 09:29 AM
Jon89's Avatar
Once you remove the plastic fender liner in the front wheel well, the sidelight assembly can be easily reached and removed....
Old Apr 13, 2022 | 09:54 AM
KRT's Avatar
KRT
thanks all i needed to know. appreciate your help.
Old Apr 14, 2022 | 04:25 PM
bcprice36's Avatar
What you have photographed is called a "Side Marker Light"!
Turn you front Wheel to the Right and push your finger in through the Fender and the Wheel Liner until you hit the Side Markers latch and push it on toward the Front....It will Pop-out as you push it forward....Hopefully someone will send a Photo for you to use!
Billy Clyde @ Cinco Ranch
Old Apr 15, 2022 | 04:16 AM
KRT's Avatar
KRT
Thank you, planning to try and get replaced this weekend
Old Apr 15, 2022 | 10:27 AM
bcprice36's Avatar
KRT,
This would be a great time to change the Lens from the old Amber to Clear Lens....Makes the Car look more modern.....
Old Apr 15, 2022 | 11:50 AM
KRT's Avatar
KRT
Well i've got the amber lens on order and will arrive on Saturday, so i think i'll see how this goes and maybe do that down the road. Thanks for the suggestion though
DNShade
Jun 28, 2021 06:55 PM
Dennis07
Nov 27, 2019 12:53 PM
whitek03
Nov 20, 2016 07:37 PM
rothwell
Feb 23, 2014 04:05 PM
Frog
Oct 17, 2011 03:31 AM
