1997 xk8 neutral safety switch
Old Dec 12, 2023 | 04:47 PM
joekluger's Avatar
Cool 1997 xk8 neutral safety switch
Im trying to remove the neutal safety switch. I located the switch on the trany but i cant seem to find where its pluged into. The wire goes to the top of the trany and feels like its straped or bolted to the top of the trany. Cant find where its pluged into to remove the switch. any help with a pic would be great. its a 1997 xk8 US left driver.
Old Dec 13, 2023 | 09:28 AM
michaelh's Avatar
Default Do you mean transmission rotary switch?
It's mounted on the top of the bellhousing, under the throttle body. See this post from stevepaa:
https://www.jaguarforums.com/forum/x...4/#post2237042
It's the one on the right in his pic. Note the wire colours differ from '97 diagram
Old Dec 13, 2023 | 09:57 AM
joekluger's Avatar
Thank you .. I see its behind some large connector. Have to remove the connector to get to the clip. Would you know if the wire is cliped to the tranmission?
Old Dec 13, 2023 | 10:24 AM
michaelh's Avatar
I'm not sure, sorry.
There is a plastic ducting running across under the scuttle which the loom appears to enter.
I'd take the TB off as it's only 4 bolts and a gasket. Should save you some grazed knuckles.
Old Dec 13, 2023 | 10:33 AM
joekluger's Avatar
I removed the large plug. Looks like the connector is the black one to the left. Looks like its going onto a plastic box but dont see anyway to ope the box to pull the plug down and out. Any ideas?
Old Dec 13, 2023 | 10:50 AM
joekluger's Avatar
Looks like it goes into a box but i cant open it cus there is a metal bar running across the top of the box. WOW. any idea? Thanks again
Old Dec 13, 2023 | 11:19 AM
michaelh's Avatar
Hi - my bad - I got the wrong half of the connector. It's the bottom that connects to the rotary switch.
I've attached the JTIS procedure, which also shows the location of two harness clips on the transmission.
File Type: pdf
Old Dec 13, 2023 | 05:26 PM
joekluger's Avatar
Thank you..Thank you. Just what the doctor ordered.
Old Dec 14, 2023 | 02:05 PM
joekluger's Avatar
Job done.. No more gear box error. Thanks for your help.
jim_63219
Aug 29, 2024 01:42 PM
jim_63219
May 18, 2023 04:42 PM
05XK8cfe
Jun 14, 2015 01:55 PM
Camgear
Sep 6, 2011 04:40 PM
montywanty
Oct 2, 2009 10:30 AM
