1997 XK8 OBD2 scanner recommendations
Old Jun 17, 2018 | 11:18 AM
nielda800's Avatar
Default 1997 XK8 OBD2 scanner recommendations
Can anyone recommend a scanner for 1997 model? I have looked through multiple threads but did not find anything specific for this year make.
4.0 XK8 Coupe ‘97 236k
Old Jun 17, 2018 | 11:50 AM
avern1's Avatar
The ELM 327 with a downloadable app like torque works fine and is relatively inexpensive. The are a lot of member suggestions for different level of scan tools. Follow the link below for "Member Approved" scanner recommendations..
https://www.jaguarforums.com/forum/g...-%2A%2A-33347/
Lady Penelope's Avatar
ELM327 devise that can read beyond codes and see live sensor data as a running recordable graph as you drive around . A car mechanic friend may have one to shorten the learning curve and see the different software qualities available .
Old Jun 17, 2018 | 12:07 PM
Berglmir's Avatar
Hi!
I just ordered this one - I researched a bit and this came up quite often as a recommendation.
https://www.bluedriver.com/
I chose that one, because it has a "Life" option, which allows you to monitor a lot of different aspects of your engine while you drive.
I also like the "look & feel" of the app.
I will let you know how it works when it arrives and I have some experience using it in my car (X100 XKR 2002)
Old Jun 17, 2018 | 01:01 PM
nielda800's Avatar
I did go through that list prior to writing my post. Unfortunately didn’t find anything recommended for my model.
Old Jun 18, 2018 | 06:10 AM
Orthodixie's Avatar
Does the BlueDriver "require" a smart phone for use or can the codes be read without one?(OK, full disclosure. I still us a flip phone)
Old Jun 18, 2018 | 06:51 AM
Berglmir's Avatar
Pretty sure it needs a smartphone.
The whole "package" consists of the hardware and a free app where you can read and configure the data you want to watch.
06-XJR
Apr 8, 2017 11:22 AM
adam699
Jun 21, 2015 12:15 PM
dpm
Jun 23, 2014 11:38 AM
sfischthal
May 30, 2014 09:47 AM
satwarez
Apr 6, 2011 10:30 AM
