1999 XK8 ac
Old Sep 14, 2016 | 11:02 AM
john hennessy's Avatar
Default 1999 XK8 ac
i was wondering,
my ac and the cooling fans,
when the ac is turned on, do the cooling fan or fans turn on?
my symptom is that the ac doesn't cool as well when i am stationary or below 50 mph so wondered if the fans should be on when the ac is on to allow air to be drawn through the condenser?
Old Sep 14, 2016 | 10:33 PM
abonano's Avatar
Originally Posted by john hennessy
i was wondering,
Yes, they should kick on high when AC is turned on.
Old Sep 15, 2016 | 07:39 AM
I've moved this post from the General Tech section to the more appropriate Model specific XK8/XKR section
Old Sep 15, 2016 | 05:55 PM
Gus's Avatar
Gus
Yes the fans should go on when the a/c is turned on. I would suggest that you have your battery tested first to be sure it and the charging system is working then check the charge on the a/c system.
Gus
www.jagrepair.com
JigJag
Feb 2, 2017 12:10 PM
rf69
Sep 16, 2016 05:52 PM
mat32essex
Sep 16, 2016 11:26 AM
Darrenmb
Sep 13, 2016 08:18 AM
Blake Bias
Sep 9, 2016 08:09 PM
