1999 XKR Climate Control Issue
Old Oct 26, 2018 | 05:17 AM
David.Lipowski's Avatar
Default 1999 XKR Climate Control Issue
Hi all,
I am having the following issue with the climate control on my 1999 XKR Couple, RHD.
Pushing the On switch does nothing, holding the On and Auto togther puts on some lights on the unit (but not the LED display), you can then turn up the fan while holding these 2 buttons...
Previously had other eletrical issues (Battery has been replaced and replacement checked), stero not coming on, some fuses going but these have been resolved.
To date I have:
Checked all fuses.
Replaced the front Control Unit (Still does the same)
Appreciate any guidance.
Replaced the Climate Control ECU (pain to get to -still does the same!)
Old Oct 27, 2018 | 03:53 AM
Originally Posted by David.Lipowski
..... Pushing the On switch does nothing, holding the On and Auto togther puts on some lights on the unit (but not the LED display), you can then turn up the fan while holding these 2 buttons...
187 Views but 0 Replies as I post this. Let's see if we can get the discussion going.
Attached is the Climate Control troubleshooting section for the 1998 XK8/XKR from JTIS.
File Type: pdf
Old Oct 28, 2018 | 03:14 PM
Thanks Graham, useful guide.
Hopefully someone has had a similar issue and had resolved!
Cheers,
David
Old Oct 28, 2018 | 07:26 PM
bcprice36's Avatar
Graham, Do you have something like this File for the 2005 XKR Model......I thought you sent something out about pushing this Button while holding that Button and if such and such happens such and such vent was not opening.....are something like that.....problem is I can't find it.....
Billy Clyde
Old Nov 21, 2018 | 11:07 AM
Anyone have any ideas? Earth, connections worth checking? Can sort of use the system holding auto and pushing buttons so can still drive car but rather frustrating limited control and no display!
Old Nov 22, 2018 | 12:36 PM
Gus's Avatar
Gus
Use this link an go to fig 7.1 & 7.2
link. http://www.jagrepair.com/images/AutoRepairPhotos/jagxk1999.pdf
Gus
www.jagrepair.com
Old Nov 24, 2018 | 07:42 AM
Originally Posted by Gus
Much appreciated thanks Gus
Old Nov 25, 2018 | 07:08 PM
hirev's Avatar
pop out switches very carefully and clean behind them?
Old Dec 14, 2018 | 05:14 AM
Hi all,
Update! So I left the car running as it was a freexing day and had been able to get the blower on with no display. I then thought on a hunch I will replace the rear heater fuse (it had already been checked a few times but still!) New fuse in and the display is now working!
Thanks for eveyones help.
Cheers,
David
Old Dec 14, 2018 | 10:30 PM
volkris's Avatar
Thanks for reporting back, David! I think everyone was just completely baffled by what you were describing, so maybe this will help someone else with the same baffling symptoms.
superchargedtr6
Oct 31, 2018 07:30 PM
jag_guy_2020
Aug 16, 2014 06:17 AM
pops8713
Jun 26, 2010 02:59 PM
Alabama-Hokies
Nov 10, 2009 06:39 PM
