2000 XK8 Gas Cap problem
Old Nov 26, 2013 | 05:48 PM
Sandrahsfn's Avatar
I remember learning that my 1999 XK8 had a new cap distributed by manufacturer. Just sent me one. I didn't pay attention to why that was -- maybe that's something relative to your problem?
Anyone know about that?
Sandy
Old Aug 31, 2016 | 05:46 PM
kmeseck's Avatar
I had evap codes on my 2000 XK8. The cap looked ok. I had it smoke tested and found no leaks. Turns out "topping off" at the gas pump. (running more fuel to get it good and full) was the problem. Threw evap codes 2 to 3 days later. Stopped topping off. No more codes. Do you do this?
Old Aug 31, 2016 | 06:35 PM
dsnyder586's Avatar
I also stopped topping off, and come to think of it I used to get evap codes and not longer do.. Huh.
Old Sep 1, 2016 | 10:40 PM
silver2000's Avatar
Been chasing the P0455 leak code for two years. Replaced gas cap, purge valve, other valve. Found missing o-rings in left side filter cannister, loose hose at engine. Still haven't solved the problem. My mechanic hasn't charged me for anything in a while but he also hasn't found the problem. Very frustrating.
Old Sep 2, 2016 | 10:26 AM
kmeseck's Avatar
Silver2000: When you get gas; When your fuel pump Stops Pumping. Do you pull it out and put it away or put a little more gas in? Just a little top off will cause an evap code in 1 to 3 days. If you top off... stop doing that. If you don't do a smoke test they generally cost about 50-75$
way2far
Aug 31, 2022 09:26 AM
kelliott
May 31, 2022 05:26 PM
Russ Graber
Feb 23, 2019 11:59 AM
jdzubas
Oct 4, 2015 09:14 AM
alpecsa
Sep 7, 2015 11:55 AM
