2001 XK8 A/C compressor removal
Old Mar 15, 2016 | 07:14 AM
noterman's Avatar
Default 2001 XK8 A/C compressor removal
Anyone have any experience removing the A/C compressor. I need to replace the O rings in the back and it looks like removal is the best option.
Old Mar 15, 2016 | 12:03 PM
Gus's Avatar
Gus
You do not need to pull the compressor to replace the "O" rings on the hoses. It is not easy but you can do it.
Gus
www.jagrepair.com
Old Mar 15, 2016 | 04:29 PM
noterman's Avatar
Thanks Gus, that's just what I needed. I am going try replacing the O rings with the compressor in place. I will let you know how it goes.
Old Mar 15, 2016 | 05:02 PM
Gus's Avatar
Gus
If I recall you can reach the bolts for the lines but you will need a few extensions. I think with the compressor in place you can get your hand to both “O” rings it might be a little difficult but it is a lot less aggravating than to drop the compressor.
I hope to add all of this to my how to.
Attached Thumbnails 2001 XK8 A/C compressor removal-img_2489.jpg   2001 XK8 A/C compressor removal-img_2485.jpg   2001 XK8 A/C compressor removal-img_2486.jpg
Old Mar 15, 2016 | 08:14 PM
Addicted2boost's Avatar
I think I'd rather go to a proctologist than replace the compressor on a XK. Either way you get your a$$ handed to you and you end up with a lot less cuts on your arms.
dneu
Jan 27, 2020 09:02 AM
Iconoclast
Mar 18, 2016 06:08 PM
sg18438
Mar 10, 2016 07:25 AM
Shelorr
Mar 9, 2016 08:46 PM
