2001 XKR front shock install
Old Sep 3, 2012 | 11:56 AM
n17gary's Avatar
Default 2001 XKR front shock install
My 2001 XKR is making banging noises eminating from the front shocks (I think). This noise has always been related to worn shocks on my previous cars. How difficult is the replacement of the front shocks on the XKR? DOes it require a spring compressor tool?
Is this a DIY job--I see replacement shocks on Ebay for ~$150 each. I'm sure the dealer would take my right arm to replace.
Any advice or thoughts would be appreciated.
Gary
Old Sep 3, 2012 | 12:31 PM
dennisw's Avatar
could be shocks but i would go for the upper wishbone bushes first..jack the car up and see if any side play..you can see then if the bushes are worn
Old Sep 3, 2012 | 12:46 PM
Stamford's Avatar
Rev. Sam has a great Youtube video that shows how to chance shocks/mounts:
Old Sep 4, 2012 | 09:21 AM
n17gary's Avatar
Dennis--How difficult are the wishbone bushings to replace?? Is there a video for this??
Gary
Old Sep 4, 2012 | 10:35 AM
vettegood's Avatar
Gary, you do not give alot of info on your car, but you have stated it is XKR.
Chances are you have a CATS system which are electronically control shocks, that is a different beast altogether.
Cost and parts more expensive and different #'s.
Check to see if you have wires coming from the shock tower under the hood just above where the tires are(where you expect the shocks would be). If there are no wires coming out of shock tower (small round black caps) you do not have the CATS system then you are good to go and can go with bilstein shocks or whatever you like, but if there are wires coming out of small black caps you do have CATS system, then you need to study about the CATS system.
The parts and cost much different, the install would be reasonably the same other than the wire connectors .
You need to know this info before buying anything.
You really should take a moment and place your car information, so if you need help people can give you the correct info based on YOUR car.
Good luck and
Happy Motoring...
Old Sep 4, 2012 | 11:43 AM
dennisw's Avatar
Gary
Hello Gary
see sams video on this subject..the hardest part is getting the big bolt out..
good luck
Old Sep 4, 2012 | 12:11 PM
n17gary's Avatar
Thanks--my bad--You are correct that I have the CATS on my car. I will take a look at the wishbone bushings as a first diagnosis. I watched the videos by Rev Sam and the process does not seem too complicated at least for the non-CATS shocks. Guess its just the parts are the big difference--looks like the removal and install are the same.
My car is a 2001 XKR convertible, 65K miles. Sea Foam green painted special at factory since it was not offered that year. I have replaced hydraulic lines for convertible mechanism and preventively did a secondary chain tensioner fix as well as a leaking water pump.
thanks for the advice
Gary
Old Sep 4, 2012 | 12:27 PM
dennisw's Avatar
sam has a video on wishbone bush replacement..shows how to do it
Old Sep 4, 2012 | 01:02 PM
Gary,
You're getting good information here from dennisw and vettegood but they've had to ask for your vehicle details to be able to give accurate answers.
I've added the details you gave in #7 to your Signature for you.
toronadomike
Jan 22, 2026 10:13 PM
Beardy
Sep 18, 2015 10:00 AM
tberg
Sep 7, 2015 07:32 AM
Dallas XK8
Sep 3, 2015 12:17 PM
OkieTim
Sep 2, 2015 12:48 PM
