2001 XKR head rest motor not working
Old Oct 18, 2009 | 02:18 PM
Steve.c3h8's Avatar
Default 2001 XKR head rest motor not working
I originally posted this in the wrong model category - so I'm re-posting it here.
I have a 2001 XKR. The driver side head rest doesn't adjust. I read the post regarding the headrest cable sheath problem. My problem however is that the motor doesn't activate at all. The other seat motors are working fine, so I think it can't be a fuse.
Any ideas?
Thanks!
Steve
Old Oct 18, 2009 | 02:58 PM
test point's Avatar
That sorta leaves the switch, the connectors, the motor or the seat control module. Then these cars have a propensity to rub through the wiring insulation which usually produces a blown fuse (#1 and #8 driver fascia panel).
There are relays on the module board but no one has yet come up with the schematic for board itself.
You might try swapping the module with the passenger seat one while checking the connections under the seat.
Old Oct 18, 2009 | 09:37 PM
Steve.c3h8's Avatar
I saw a suggestion in another thread about swapping the passenger seat module with the driver seat to test some functions. Is it fairly easy to do this? Are the modules identical?
Thanks.
Old Oct 18, 2009 | 10:43 PM
Fjk's Avatar
Fjk
Looking at the wiring diag for your car, it appears the "head restraint" motor AND "head restraint" control module are located in the seat back.
All the other seat functions are controlled by the "seat control module" under the respective seat. Both are fed by the same source.
Old Oct 30, 2009 | 12:59 PM
Steve.c3h8's Avatar
I've only been a Jag owner for about a month. I haven't found all the sources of info I need yet. Where can I find a wiring diagram? Is there a source online?
Thanks!
Old Oct 30, 2009 | 02:21 PM
ken@britishparts.com's Avatar
You can get a subscription to All Data or pick up a JTIS off Ebay.
Old Oct 30, 2009 | 02:41 PM
test point's Avatar
A JTIS down load is available here:
https://www.jaguarforums.com/forum/s...ead.php?t=9933
It has all the years up through '03 and electrical schematics.
X_Type_South_Africa
Dec 9, 2015 05:37 PM
johnnie ryall
Oct 19, 2015 09:44 PM
niner nellie
Sep 1, 2015 10:53 PM
perfectphoto
Aug 30, 2015 01:15 PM
dpappyp
Aug 27, 2015 06:31 AM
