2003 4.2L with a 5-Speed?
Old Aug 27, 2013 | 06:31 AM
warwickhw's Avatar
Default 2003 4.2L with a 5-Speed?
I'm hoping someone can answer this question before I buy a new XK8, which is in good condition in all respects.
Its a 2003 model, 4.3L. My understanding is that when Jaguar replaced the 4.0L in 2003, they also replaced the 5-speed auto gearbox with a 6-speed Mercedes box.
According to the AA check I had carried out on the vehicle, the gearbox is a 5-speed.
Is this OK? Should I be concerned?
Many thanks in advance for any suggestions.
Old Aug 27, 2013 | 07:07 AM
WhiteXKR's Avatar
There are some inaccuracies in the above statements.
-4.0L normally aspirated had a ZF 5-speed
-4.0L supercharged had a Mercedes 5-speed
-4.2L (normally aspirated and supercharged) had a ZF 6- speed.
So...the 2003 4.2 should have a ZF 6 speed.
Old Aug 27, 2013 | 07:17 AM
Frog's Avatar
That's the first time I have heard of a 4.2 with a 5-speed 'box.
Old Aug 27, 2013 | 07:38 AM
Welcome to the forum warwickhw,
As the others have said, a 2003MY should have a 6-Speed transmission.
Probably nothing more than a typo on their part but it would raise my concerns to check it definitely is a 2003MY fitted with a 4.2 litre/6-Speed and not a re-registered earlier 4.0 litre/5-Speed with some dubious history.
Old Aug 27, 2013 | 07:44 AM
They could be confused with the numbering on the J gate.
Does it look like this with numbers up to 5?
If so it is a six speed box.
Old Aug 27, 2013 | 08:19 AM
Frog's Avatar
Good point. To a non-Jag nerd, the 6-speed selector does appear to indicate there are only 5 speeds.
Old Aug 27, 2013 | 09:20 AM
warwickhw's Avatar
@GGG - many thanks
@Norri - many thanks to you too - especially as your post seems to have cleared up my question. The AA engineer would have looked at the J-Gate layout and assumed 5-speed.
This is clearly an excellent forum and I look forward to buying my first Jag safe in the knowledge that there is a solid community supporting my choice.
I am now going to try and buy it!
Old Aug 27, 2013 | 09:55 AM
Good Luck!
Old Aug 27, 2013 | 06:58 PM
BurgXK8's Avatar
Ok, I'll bite - what's an AA engineer? Is Alcoholics Anonymous installing an ignition interlock on your car?
Old Aug 27, 2013 | 07:04 PM
Steve8's Avatar
Lol. AA is the (non American) Automobile Association
Triple A minus one
max224
Jun 21, 2024 12:17 PM
Msteiner
May 16, 2016 12:19 AM
jospolice
Oct 2, 2015 07:16 PM
jospolice
Oct 1, 2015 07:52 AM
GoNavyMike
Sep 28, 2015 08:56 AM
