2003 XK8 cruise control basics
Old Mar 28, 2023 | 06:46 PM
66RBS's Avatar
Default 2003 XK8 cruise control basics
Gentlemen
I have a 2003 XK8 with the standard cruise control (not adaptive ACC)
When the cruise control is engaged I do NOT see any indication that cruise control in on but it is functioning via the 4 steering wheel control buttons
I didn't see anything in the owners manual showing a dash indication of on or speed etc
Just checking Is there an indication that the cruise id on?
Randy
Old Mar 28, 2023 | 07:53 PM
RJ237's Avatar
You should see a brief message saying cruise control engaged.
Old Mar 29, 2023 | 09:50 AM
66RBS's Avatar
Default XK8 cruise control
not seeing anything. Assume display would be in odometer display
Old Mar 29, 2023 | 07:19 PM
RJ237's Avatar
Yes, it would. But the cruise control does work? If it does, accelerate while in cruise and look for a 'cruise override' message.. There should also be a 'cruise disengaged' when you cancel.
Old Mar 29, 2023 | 10:33 PM
66RBS's Avatar
Default Cruise control
Yes the cruise control works but no instrument display that it is engaged
on startup the system goes into a brief system check and I do not see any lights related to cruise control so maybe I have a Burned out bulb
at least the cc works
Randy
Old Mar 29, 2023 | 11:00 PM
bazjag's Avatar
No display on our 2003 XK8 so same as Randy. If a fault then our car has the same.
Old Mar 30, 2023 | 01:53 AM
baxtor's Avatar
I only have direct knowledge of my 2000 MY but no messages and no problems with cruise control.
There does not appear to be any CAN involvement unless adaptive cruise is fitted and l can find no messages related to cruise listed for message centre.
Old Mar 30, 2023 | 02:52 AM
dibbit's Avatar
The earlier cars with the cruise on/off switch by the j-gate don't show any messages. I had always assumed that the later cars without this cruise on/off switch did show a message instead - odd that they don't.
Old Mar 31, 2023 | 06:42 AM
Orthodixie's Avatar
My ‘04 does display the “engaged” and off msg.
66RBS
Nov 21, 2021 08:39 PM
adriandoble
May 23, 2020 12:28 PM
Noswagr
May 6, 2018 04:04 PM
Davexjrv8
Nov 29, 2011 09:38 AM
dutch
Aug 8, 2010 03:12 PM
