2003 XK8 cruise trouble
I have a 2003 XK8 and recently have been experiencing a trouble with the cruise control. The warning comes on the dash CRUISE CONTROL NOT AVAILABLE CHECK REAR LIGHTS. well I have checked all of the rear lights and they are all good but the warning keeps on appearing. Has anyboby had the same problem and what was done to correct it.
Welcome to the forum bryaneva11,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
You think your brake pedal switch is working fine but it is highly likely that your fault is indeed there. The dash messages "Cruise Control Not Available" and "Check Rear Lights" together is almost always due to a failing brake pedal switch. Search this forum using "faulty brake pedal switch" and you'll read many, many posts about this issue. The fix is either a new brake pedal switch or some cleaning and re-soldering of your existing brake pedal switch....
Search, read, and learn....
The Brake Pedal Switch has 2 sets of contacts:
A N.O. Set Activates the Brake Lights.
A N.C. Set Enables Cruise Control.
If the N.C. Set is bad, The Brake Lights will still work but no Cruise Control.
I had the same problem a member on here does an excellent repair service see link below, I can highly recommend him
https://www.jaguarforums.com/forum/x...ics-faq-37758/
I had the exact same indications last year. I remember folks hear talking about the brake switch, so I sort of "popped" the pedal a few times (let it fling back to the up position). Sure enough everything worked fine. And the problem hasn't returned. I hope (for both of us) that it's just some dirty contacts or some such phenomenon.
