2003 XK8 front end bushings avail in a kit?
Old Apr 1, 2015 | 11:44 AM
brgjag's Avatar
Default 2003 XK8 front end bushings avail in a kit?
Well recently a shop told me I needs bushing up front. Are there any kits out there that are avail that will cover most of the bushing needed? I was told the ball joints are fine. told control arm bushing are bad, sway bar, top shock mount bushing, prob lower also.
Old Apr 1, 2015 | 02:10 PM
blindside's Avatar
Default Powerflex bushings
I saw these guys HERE mentioned in other posts and I think they were happy with the results... worth a check.
Old Apr 1, 2015 | 02:27 PM
brgjag's Avatar
that is a start but they don't appear to carry everything
Old Apr 1, 2015 | 02:36 PM
woox4's Avatar
Jaguar XK8 XKR Front Suspension Replacement Metallastic Bush Kit | DCR AutoParts
Old Apr 1, 2015 | 03:05 PM
blindside's Avatar
Well, it seems to cover everything that you mentioned with the exception of the shock mounts and bushing (lower)... the shock mounts need to be sourced separately (I got mine on PartsGeek) and if you are going to replace the lower shock bushings you may as well just replace the whole shock given the cost.
Old Apr 1, 2015 | 03:14 PM
brgjag's Avatar
I think I need springs also. Even with the bad top mounts it sits really low in front. I priced everything a couple ways and to go all out short of ball joints I was in the 1500-2k range just in parts.
Old Apr 1, 2015 | 09:37 PM
Jandreu's Avatar
Man that's expensive. I replaced everything, upper lower ball joints, tie rod ends, sway bar links, shocks, upper shock mounts, shock gator, upper and lower control arm bushings on both side for just a little over 1K with shipping costs to Hawaii.
Old Apr 2, 2015 | 12:15 PM
DevonDavid's Avatar
"if you are going to replace the lower shock bushings you may as well just replace the whole shock given the cost."
That's certainly not the case here in the UK.
2 x Lower shock absorber bushes = $45
2 x Shock Absorber (standard not adaptive) = $520
Forum discounts or "shopping around" might get a small reduction on those prices, but in any event - quite a difference !!
I only know this because I recently went through a fairly complete front suspension overhaul. The lower bushings are quite complicated, more like a universal joint than *just* two bits of rubber or polyurethane. They are not easy to replace but the saving in cost is significant.
Old Apr 2, 2015 | 04:25 PM
blindside's Avatar
Here in the states, the bushings are available at PartsGeek for like $71 each and Bilstein shocks are $114 at Advance Auto... for the extra $43 a side I would definitely replace the shocks if I were doing everything else.
Amazing the price differences on each side of the pond...
Old Apr 2, 2015 | 04:27 PM
SNG Barratt USA's Avatar
Former Sponsor
www.sngbarratt.com/PartSearchResults.aspx?partno=SU3017PB
Standard bushes also available...
BrentGardner
29
Dec 16, 2024 12:13 AM
philwarner
Dec 6, 2021 07:13 AM
tberg
Sep 7, 2015 07:32 AM
CaneCounsel007
Sep 3, 2015 07:33 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
