2003 xkr rear a-arm bushings? do these wear a lot?
Old Mar 13, 2012 | 04:04 PM
deadboy1977's Avatar
Default 2003 xkr rear a-arm bushings? do these wear a lot?
reason i am asking is that i went for inspection and the mechanic was able to move/rock the rear wheels a bit (fronts are tight). His guess was the rear a-arm lower bushings....both sides rock the same though so I dont know if they are both worn or if thats the way they are supposed to be??? If they do wear a lot and should be replaced, go with jag originals or are there better aftermarket bushings? I assume these are solid busings in the arm? or are they rubber? thanks for all responses.
Old Mar 13, 2012 | 04:44 PM
Skid Mark's Avatar
Is it the bushings where the spindle attaches to the control arm or where the control arm attaches to the sub-frame? Either way, if it didn't knock or give me alignment/tire wear/handling problems I'd leave it alone.
Old Mar 13, 2012 | 06:03 PM
lower OUTER near the spindle it seems ... i jacked it up and took the tires off and (to me) i cant see any movement in this area but i do fel movement, more than one would expect, but i have no reference point...to me almost seems like the bearing nut needs to be tighter....
Old Mar 13, 2012 | 08:44 PM
Beav's Avatar
Are you certain it isn't play in the axle shaft bearings at the diff? The axles act as upper transverse links and it's common for there to be a little play there on Jags.
Old Mar 13, 2012 | 09:27 PM
H20boy's Avatar
My indy jag shop diagnosed that very same movement (12 & 6) on the rear as wheel bearings and installed a more robust aftermarket brand. It did correct that.
Old Mar 14, 2012 | 07:37 AM
what brand wheel bearings did you install?
Old Mar 15, 2012 | 12:35 AM
H20boy's Avatar
I think SKF, my invoice says QWB708 Wheel Bearing Kit, a google search turns up SKF as the manufacturer.
toronadomike
Jan 22, 2026 10:13 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
Beardy
Sep 18, 2015 10:00 AM
obwoodie
Sep 3, 2015 07:45 PM
OkieTim
Sep 2, 2015 12:48 PM
