2007 XK8 Coupe - Same bad radio reception
Old Apr 21, 2007 | 03:06 AM
mkranitz's Avatar
Default 2007 XK8 Coupe - Same bad radio reception
I drove a 2000 XK8 for 3 years and all during that time, the radio reception was not very good (metro Denver).
I sold that car and now have a beautiful new black/alum 2007 coupe and local radio stations that my wife's car pick up fine go in and out and have low levels of static.
Anybody else have this issue??
Michael
Old Apr 21, 2007 | 06:00 PM
Envy337's Avatar
Default RE: 2007 XK8 Coupe - Same bad radio reception
Do you have a satellite radio installed?
Old May 4, 2007 | 04:25 PM
mkranitz's Avatar
I do, but haven't activated it yet. I think that may be the only solution (or is that the problem?)
Old May 7, 2007 | 08:32 PM
Envy337's Avatar
Well, if the satellite radio is on (even if it's not activated) it will cause your FM/AM reception to be bad.
Turn it off and the reception will improve.
Old May 15, 2007 | 12:25 AM
mkranitz's Avatar
Oooohhh...now that is a great hint. I hope I can figure out how to turn it off! I'm sure it's in the configuration screens.
Old Apr 9, 2012 | 02:47 PM
tapollo's Avatar
Why not temp. plug an external antenna into the module with antenna and rear window defroster?
Old Apr 9, 2012 | 03:04 PM
mike mitchell's Avatar
my 97 xk8 has static on am. cant use it.
Old Apr 10, 2012 | 12:51 AM
tberg's Avatar
My 2002 XKR has terrible static on AM while driving but not while stopped or when going over a bump or hump in the road, drives me crazy.
Old Apr 10, 2012 | 05:06 AM
WhiteXKR's Avatar
There is a braided wire that connects the antenna in the trunk to the car's body. Remove it, clean the connections with some fine sandpaper and reattach it tightly. This may help.
Old Apr 10, 2012 | 08:46 AM
BlkCat's Avatar
Yeah, if sat radio is on, FM/AM reception will be awful. I have to turn Sirius off if I want to get FM/AM. This is not a Jaguar issue. I had the same thing with my Miata.
Jack
Old Apr 10, 2012 | 01:59 PM
vettegood's Avatar
Default External antenna install
I would like to hook up an external antenna 2001 XKR but cannot find an adapter to work with the radio feed line in trunk.
I do not want to destroy existing connectors or factory antenna and do not want to rip out center console and radio just to plug in a Motorola jack from new antenna to the back of radio.
Anyone know how to connect an external antenna in the trunk area with existing feed cable?
The existing jacks are similar to a coaxal cable but smaller, it has a hard main copper wire (like coaxial) that plugs in to female plug and allows the signal to go to radio from factory antenna. The plug from antenna is the male end and the plug going to radio is the female end.
I need an adapter with the male Jaguar connector and a female Motorola plug.
Want to just plug in the external antenna Motorola jack into adapter cable to the existing cable from radio in trunk area, by the amp and CD player.
Anyone ever hook up a and/or have experience with "TuneTrapper" antenna?
I understand they are quality and handmade in Florida, hand tuned for FM but gets good AM signal as well. Thanks
Old Dec 29, 2012 | 07:18 PM
bobson2's Avatar
Hello,
My 2001 xkr has exactly the same problem. If you figure it out, please let me know. I will do the same.
Yours, Ken
philwarner
Oct 4, 2024 01:37 PM
Burdedw
Sep 12, 2015 10:39 AM
Nasayr
Sep 9, 2015 06:20 AM
DEklof
Sep 8, 2015 05:28 PM
jfitzoz
Sep 7, 2015 04:28 AM
