3rd Brake Light on a Drophead, Removal
Old Mar 20, 2013 | 02:30 PM
Padrino's Avatar
Default 3rd Brake Light on a Drophead, Removal
My XK8's at the shop getting a total repaint (and color change to 'Sable', the early '70's XKE color. Original is a Sherwood Green) and I've had the 3rd brake light removed and holes plugged for the painting. Just wanted to clean the lines along with removal of the body side moldings. What 'technical' issues if any will I run into? Thanks.
Old Mar 20, 2013 | 03:29 PM
Jag#4's Avatar
Someone else will need to address the technical issues (codes may appear for brake light out), but the larger issue is legality. I bet in CA this is a No-No. Better check first.
Old Mar 20, 2013 | 05:56 PM
Padrino's Avatar
Not an 'uncommon' mod out here on the high end cars which doesn't seem to get too much notice by LEOs.
Old Mar 21, 2013 | 02:29 AM
XKRacer's Avatar
No problem with faults, just remove it like you have done
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
PMKimpton
Aug 3, 2019 08:22 PM
OkieTim
Sep 2, 2015 12:48 PM
