6HP-26 Transmission slip 6-5
No info found on this
My XK8 seems to slip and throws a gearbox fault code when I kickdown from 6-5. However, all upshifts and other downshifts are smooth. Also, if 6-5 downshift is performed by J-gate manually or decreased speed, it shifts fine
Any thoughts?
Any thoughts?
I would start with a fluid change on the transmission and filter change. Also replace the sleeves and connector block to the mechantronix unit. Normally that will fix most problems. Like this GENUINE ZF 6 SPEED 6HP26 6HP28 6HP32 6HP34 SLEEVE TUBES AND ADAPTER SEAL KIT OEM | eBay
If the codes suggest anything wrong with any of the solenoids valves, you might need/want to replace them. There are kits available. The solenoid valves are on the valve body, (easily?) reachable from the bottom. Some go further and procure a replacement rebuilt valve body, including the valves.
Best of luck, keep us posted.
AND, it's a Crap Shoot if you develop a "SQUAWK". The initial change on mine was great. Filter & fluid, all was good. Next time, same procedure and we had the SQUAWK. . Downshift from 6th to 3rd or 4th and was very irritating. Jaguar discontinued the Additive separately but it is now in LG-6. Since the Ford 6R80 is a ZF licensed design of the 6HP26, Ford had a similar problem and has a kit,
Motorcraft XL16. We used this and now there is no Squawk on kick down. Use the suggested amount. XL16 cost us $75 and required google search. Hope this does not deter you from the service.
* Did you use the single "T" syringe or the twin "T and F" syringe kit?
* Where did you find the suggested amount?
Later edit, found a useful video on the XL16 Kit: search YouTube for "VsPetsHaKcU"
A related question: Say one has the gear box correctly filled to the "full" level so that the transmission fluid barely weeps out the fill aperture (while the engine is running, with the transmission fluid in the required temperature range) . Now, if one then has the same gearbox COLD/engine off and removes the transmission fill plug, will the transmission fluid leak out the fill aperture or not?
A few questions from a squawker. I did a search on Motorcraft XL16 sales and got two types of hits. One type shows a single syringe of additive being sold with a label of "6R ATF ADDITIVE T" . The second type shows a two syringes, one of additive with a label of "6R ATF ADDITIVE T", and a second syringe of additive with a label of "6R ATF ADDITIVE F", with the twin syringe package labelled "Motorcraft 6R ATF Additive Kit XL16".
Finally borrowed a diagnostic computer, scan results show 5th gear ratio fault code. No solenoid codes. Will continue with oil, filter, and seals change first.
Also, I did hear sqwak noise occasionally. I’ll try the additive, too.
Thanks for the useful intel everyone
LarWarrior42
Sep 8, 2023 12:38 AM
ColtMiller
Jan 10, 2022 07:02 AM
Scottfree
Oct 19, 2021 04:52 PM
