6HP26/28 Bridge Seal Will Not Fit
Old Jul 24, 2020 | 11:05 AM
Lannyl81's Avatar
Default 6HP26/28 Bridge Seal Will Not Fit
About a year ago I purchased a filter kit for the '06 XK8, (6HP26 trans)....and just now started this job. Got the mechatronics out, changed the tube seals with no problem...but the bridge seal I received from thectsc.com will not fit. The bridge seal has the correct markings on it....6HP26/28....6HP32/34...but is has the tab that the 6HP19/21 seals uses. What gives??
Anyone run into this?
Old Jul 24, 2020 | 11:36 AM
Lannyl81's Avatar
Did a bit more research, found the ZFpart number on the seal I have.....turns out it is for the BMW ZF 6HP26/28....not the Jaguar XK8. Of course I no longer have the receipt, not even sure I purchased this from thectsc.com or not....so much for my records!
Ordered the correct one.
Old Jul 24, 2020 | 03:24 PM
giandanielxk8's Avatar
Can the tab be carefully cut out?
Old Jul 24, 2020 | 05:12 PM
Lannyl81's Avatar
I started cutting the tab off, stopped, but then decided I had nothing to lose, got it trimmed off. I want to put a file on it to get it nice and smooth....but I think it will work just fine.
Back under the car tomorrow...
Old Jul 25, 2020 | 05:40 AM
Jon89's Avatar
I doubt that Klaus (at thectsc.com) would make that mistake so I am betting that you sourced the part from somewhere else. Good luck on cutting the tab off and keep us posted on how it works for you....
Old Jul 25, 2020 | 01:31 PM
Lannyl81's Avatar
thectsc.com replied to my email...and yep...for some unknown reason to me....I purchased the bridge seal elsewhere....???....have no "&#!!)#*^!!" idea why....but I did.
Anyways thectsc.com suggested that I trim the tab off....which I did, got it nice and smooth, almost like it was never there. (I did not take a picture) Bridge seal fit with no problem.
Lesson learned here is that the BMW 6HP26 bridge seal will fit into a Jaguar 6HP26 with a bit of trimming.
Old Jul 25, 2020 | 03:13 PM
Jon89's Avatar
Well done and happy motoring....
John Baker
Jun 3, 2020 05:00 PM
JensenHealey
XJ40 ( XJ81 )
Feb 8, 2020 01:00 PM
dgutzke
Dec 1, 2017 01:31 PM
tedwone
Jul 1, 2017 01:35 PM
