97 seat module
Old Apr 2, 2011 | 01:53 PM
customstairworks's Avatar
Cool 97 seat module
I am still on a search for a pass seat module. The driver seat has the same part # and I switched them to diagnose the problem. Will the circuit board of of a module from a98-03 xj or xk work. They have the same wiring connection plugs, but a different style of mounting bracket.
Old Apr 2, 2011 | 03:04 PM
WhiteXKR's Avatar
What are the symtoms of your bad seat module? There is a common fault that can be repaired with a little soldering skill if you search the forum.
Old Apr 2, 2011 | 11:52 PM
everything is not functioning. the circuit board looks fine without any breaks. Not sure why it went bad, I was just informed about it when I bought the car. I looked through all the repair orders on the car and the local dealer had pulled the seat out and replaced the switches back in 2001 in the same seat. Sometime after that an independent repair garage replaced a bolt that fell out of the seat. Makes you wonder about the competency of the local Jag shop. There were other things that were warrantied at the dealership along with the exhaust tailpipe being loose, which explains why the tailpipes are all crooked and misaligned.
knightofgold
Feb 11, 2016 06:03 PM
JeffinSwitz
Sep 16, 2015 01:44 PM
multijag
Sep 14, 2015 04:54 PM
Clamdigger
Sep 12, 2015 03:43 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
