97 XK8 back windows & open hood code
Old Dec 3, 2009 | 11:05 AM
ken@britishparts.com's Avatar
My guess is there is something stuck or a problem in the latch.
Old Dec 3, 2009 | 03:30 PM
H20boy's Avatar
I would do a manual open/close and see if it clears the error. First though, do a hard reset at the battery (disconnect negative terminal and briefly touch positive), see if the battery drain was a cause.
Old Dec 3, 2009 | 06:33 PM
sparkenzap's Avatar
you might find better help in the XK forum since we don't have drop tops on XJ8s.
Old Dec 3, 2009 | 08:33 PM
H20boy's Avatar
didn't see it was in the XJ section! nice catch ross
Old Dec 3, 2009 | 09:12 PM
Gus's Avatar
Gus
Originally Posted by wikdzr1
Hello, last week I left the key in my car and the bat was dead, after charging I tried to start and the back windows went down & stayed down. The windows will not rise & my convert top will also not work at all. I also have a HOOD open code? any Ideas
Regards,
Brett
Your roof is operated by hydraulics and a series if relays and switches and the icing on the cake is that it is all controlled be your security and body control module. When the battery went down your system went out of sequence. Charge your battery, check your latch locked properly with the allen wrench and give it a try again. From what you are saying the latch is open and you need to close it first before the windows will close. The windows open first and close last after everything is the way it is supposed to be. Removing the power and reconnecting is at times necessary but when you remove the cable remove it and when you connect it back trying doing it without creating static and count to ten before going back.
BrentGardner
29
Dec 16, 2024 12:13 AM
msdg137
Sep 16, 2015 06:24 AM
jbjb_007
Sep 1, 2015 02:02 PM
plmmd
Aug 31, 2015 10:07 AM
Jandreu
Aug 29, 2015 07:31 PM
