'97 XK8 - can't remove corroded rotor
Old May 3, 2013 | 12:07 AM
PattertiXK8's Avatar
Default '97 XK8 - can't remove corroded rotor
The rear brake rotor of my '97 XK8 is corroded onto the hub. I've tried penetrating oil, heat and a hammer with no success. The heat was one of those propane bottles from Home Depot. Not sure if a hotter torch would make a difference. I'd rather not cut it off with a grinding disc if there is an alternative. The rotor itself is fine. The emergency brake inside has seemingly come apart and is rattling.
Anyone have any suggestions?
Old May 3, 2013 | 03:14 AM
Did you back off the Parking Brake adjuster before trying to remove the brake disc?
If you're not familiar with the setup, the Parts Catalogue makes the Parking Brake adjuster a little clearer:
The adjuster has to be backed right off or the disc is held firmly on the hub by the Parking Brake shoes. The rattling could be one of the springs come loose as you've been hammering to try and free the disc.
Old May 3, 2013 | 04:22 AM
ccfulton's Avatar
+1 on releasing the park brake tension.
A trick I have used is to put a 3/8 socket extension into the vent and use it like a handle for more leverage.
Old May 3, 2013 | 06:43 AM
WhiteXKR's Avatar
Sometimes you just need a bigger hammer
Use a good sized hammer (a short handled sledge hammer) and keep rotating the disk as you hammer.
Old May 3, 2013 | 07:27 AM
I got this sneak pic of WhiteXKR troubleshooting his latest project:
Old May 4, 2013 | 09:18 PM
mike6348's Avatar
You can try using a mapp gas handheld torch. It will get hotter than just propane and you should be able to buy one from home depot.
I have also heard you can try putting the wheel on loosely and then try moving the car backwards and forwards and then slam on the brakes. There is usually a little bit of rotational play between the rotor and wheel studs with the wheel usually holding it in place. If you loosen the wheel the rotor should be able to rotate a bit and the brakes may break it loose.
Never tried it so have no idea whether it would work.
Old May 5, 2013 | 01:52 AM
dannyS's Avatar
Hi there. I recently replaced all four rotors, and encountered some of them being stuck as well. I used a crowbar wedged in between the rotor itself and the solid chunk of steel that holds the caliper in place. One solid pull on the good length crowbar and everything goes .
Be careful not to damage the caliper bolt holes.
Good Luck!
Old May 6, 2013 | 06:47 AM
MustangSix's Avatar
One other trick is to simply loosen the lug nuts, then as the car rolls, hit the brakes hard. The shock is usually enough to unstick a rotor.
Obviously, don't go more than a few feet or very fast.
H20boy
Dec 24, 2024 03:23 PM
99xk8guy
May 28, 2024 09:36 PM
timm525
Sep 8, 2015 07:57 PM
handcuffsready
Sep 7, 2015 01:02 PM
JagLove86
Sep 6, 2015 10:36 PM
